Western Thunderer
Many years ago in my wage slave days I worked at a day centre. The caretaker's duties included a daily check of the minibus; he had a special stick which fitted between dash and brake pedal so that he could check that the brake lights worked. Being a bit of a prankster I hatched a plan to borrow the stick each day when the caretaker was on his lunch break and shave a small portion off, the idea being that the stick looked the same but got increasingly difficult to position effectively.
Could you not employ the same technique Simon? "The lawn's looking a little scruffy darling; I'll trim the edges."
.......I'm not sure about the steel section idea though personally, it could take forever to construct & prove heavy & cumbersome to set up ?
......... but I designed the garden from scratch with raised erm flower beds that just happened to plot the path of a garden railway
A bit more fired up after this weekend though, some infectious enthusiasm from Simon, plus a chance to catch up and chat with friends at the Shepshed show and the S Scale Society meet has seen some sparks of life in the mojo department. Got out in the garden on Sunday morning, a quick rail clean and plug in of all the controllers and it all still worked! No electrical joint failures so the stock came out for a run. Disappointingly, the Pannier played up, creeping along despite the controller being set to zero - this meant the auto shuttle function was next to useless. Can't figure out what has changed between now and the last time it ran, but the Ruston stopped working in sympathy about an hour later
