These aren't the posts that you are looking forwere going to get into trouble if we continue this grand master Jordan and Obi wan will blast us
A spot of dry weather meant I've been able to get out and trim up the bushes, sort out a failed soldered joint on the track and get the Multimaus installed on its shelf in the shed.
to make nice smooth track connections between the removable bridge & the permanent line
) and the second for the 16v AC supply needed for the smoke unit thats going in the hut.
With two of the same boxes at the station end (used to select stopping point dependant on whether the loco is pushing or pulling on arrival at the station) the Pannier spent about two hours today just shuttling up and down the line on its own accord - its a bit wierd coming out of the house and not seeing anything, then it just appears out from the shed and mooches down to the station before pausing and returning again
I need to have a play with braking distances, then the autocoach can come out to play and I'll see how / if it all hangs together as I hope.
Be a pleasureGreat progress.
I like the sound of the auto shuttle jobbie, you'll have to help me set up one on the branch in my garden (if it ever gets built).
Chin up misterAt my current rate of progress you'll probably be christening the finished job with my ashes![]()
I reckon its been just under four years since the bridge went in, then we had the marathon garden weekend in April 2009 to get the base laid around the back of the shed. Given the amount of work you've put in to create all of the trackbed on the other side of the bridge, I wouldn't be despondant at progress at all
Yours is a hardcore build (in more ways than one). As I likes building stuff, do you want to schedule in another 'Post Camrail Weekend Working Session'
.... Part of my despondency is the total opposition of Mrs Simon to the next phase. Despite being a firm believer in a "the sale starts when the customer says no" philosophy of marriage I think I am going to have to concede to near impossible lunacy and make the sections across the lawn removeable....
Weird coincidence; just before we went off to Looe for a week I was going to suggest that removeable sections to bridge the gap across the lawn might speed up progress on the circuit and allow trains to whiz all the way round your garden this year rather than ten years hence. I had in mind some welded sections that would piggyback off each other supporting some fairly robust flexitrack, rather than the super-scale stuff of the permanent parts, that would allow the concept to be realised.
Who or what are you flicking the slugs at?
) - this seems a good way to get what you want without upsetting Mrs Simon. Of course, I'm with Neil and just want you to get a loop done as fast as possible
), then embrace the fact that you have the space and opportunity to create a fantastic garden line. It will still be fantastic, even if bits of it can be taken up and stored somewhere else.
. Right time to hide before
hits the fan.
Could'nt you persuede SWMBO and split the lawn in two with a narrow rockery ( just wide enough for the track ) and have just a lift out section for passage through ( oh and mowing ). Just a thought as i know these women are Very Hard to please.
If you do mention it to SWMBO and she wants to kick your dangly bit for suggesting such a STUPID idea , you didnt get it from me. Right time to hide before
hits the fan.
Rob![]()
How long will the removable section have to be in order to complete the continuous run Simon ?
