Thank you Richard. It feels dreadful to put nice prints in the bin, particularly as it took more than a couple of goes to get to this point, but they’re dimensionally wrong, and there’s little point in keeping them when I now have good data, and the CAD is now as good as I can make it (with more than a little help from Nick @magmouse)I wonder if a few people would find the gash prints useful for painting and weathering practice. Seems a shame to put everything in the bin.
)with more than a little help from Nick @magmouse
Black art.......The printer ran last night, and the print appears to be successful.
the differences were
A) I turned the printer off at the mains for several hours before turning it on to run the print. It’s been plugged in and on at the mains since I got it, but, well you never know.
B) I used a different memory stick, and copied the print file from the laptop
C) I violently shook the resin bottle about 10 minutes before pouring the resin, I don’t know if it separates. The bottle sits on a reptile mat so it’s gently warmed.
D) it wasn’t Christmas Eve but All through the house Not a creature was stirring Not even a mouse;
dunno…
I missed this,Thanks Rob,
if you’re slicing strips off the edge of a sheet, how narrow can you go? I understand it’ll depend on thickness. Do you find the strips curl?
ta
Simon
Rob,It's worth mentioning that I did have to adjust the base plate so that it was closer to the blade to get a good cut. When it arrived, it had a tendency to push thin strips down between the base and the blade rather than shear them. Easily fixed as the base is adjustable.
There is also a sprung bar which is designed to hold the material down and keep your fingers away from the blade I'm sure it does if you are cutting big pieces. For the small strips etc that I cut it makes it difficult to see to align your cut off marks so I removed it.
I also replaced the 'guide' which is meant to help you keep your material square to the cut but it was tiny and so completely ineffective. I made one from more substantial material but I have been considering how to mount a section from a thick steel ruler which would hopefully allow measuring cuts on the fly.
I have a photo somewhere of the replacement, I will dig it out, although as an engineer I am sure that you will come up with a much more elegant solution than I did.
Hi Ian,Rob,
A rule against the guide is useful but doesn’t always give identical sized pieces. I have one on my Metalsmiths guillotine which I keep for platework. I have another heavier machine, German and aimed at the school market, which I use for heavier stock for loco frames etc.
If I need to cut a number of pieces exactly the same size I use an adjustable stop on the rear so that pushing the stock against it sets the width. Before I made the stop I used the depth probe on my calipers, it worked but would have been easier if I had three hands!
Ian.
