simond
Western Thunderer
That’s only a little older than my Smallpeice!
Thanks Lawrence,I'm a late follower of the Mogul build, but enjoyed reading it so far. An interesting and thought provoking exercise well executed.
I'm fortunate in also having a homemade RSU, Unimat3, GW riveter, printers, ultrasonic etc., and would confidently tackle this kit if 7mm GWR was my thing. But my over-riding feeling as I reach the latest instalment is what a drama to build a 'kit'. I'm sure any number of prospective 7mm neophytes have fled in terror before this point. You'd have to be a particularly perverse masochist to embark on it.
'Don't attempt the kit unless you could confidently scratchbuild the model' seems to apply here?
Thanks Simon. Maybe... I've got a bit distracted here as I was told there were a couple of comments on my kits. I've got writing responsibilities elsewhere, so it's unlikely I'll post much detail. I'll probably just chip in when I think I can add something, but I don't want to hijack threads that's for sure.That’s rather nice, and perhaps deserving its own thread. I’m sure we’d all like to know more.
I agree with Simon, please tell us how you get from an idea to what we see in that last photo.That’s rather nice, and perhaps deserving its own thread. I’m sure we’d all like to know more.
These days I only build my own kits on the whole. Mainly as I'm the only one who makes kits for the things that I want. Any kit is a compromise. The advantage of building your own is that the compromises of the designer and builder match perfectly, so no rework is ever required (well not due to the specification at least).
This is an NZR Wa class c.1940 in Sn3.5. 16.5mm gauge. All ns/brass/cast bronze, in 'works' grey. Split frame, metal wheels. Photo lit with an LED array, hence some odd shadows. Still needs the glazing, weather shields and one or two tidy ups here. The backhead is a 3D print, though not yet fitted here. It's fragile, but pretty safe tucked in the cab.
It is, but the actual build process is temporally offset, so it feels like kit building. So offset, that I need to read the instructions sometimesLawrence,
If you only build kits designed by yourself is that not just scratchbuilding?
Ian.
Seconded!I agree with Simon, please tell us how you get from an idea to what we see in that last photo.
Rgds, Graham
Just so you know.... I'm pinching this idea for jigging frames and rodsSo, rods assembled, jig set. I didn’t leave quite enough clearance vertically to be able to have the rods on the spigots, whilst the hornguides are fitted to the guide blocks, but I could assemble them on both sides before tightening the M5 nuts & T-bolts which clamp the guide blocks on the extrusion. Should have printed them about 5mm taller.
I have just popped the rod on this side to double check that nothing has moved.
All in order
The frames were clamped together and I opened out the slots until they just fit snugly over the hornguides.
yup, as a bug in a rug.
Frames polished with emery cloth, joints fluxed, short lengths of 0.7mm flux-cored solder on each horn leg. Break out the RSU…
Home made back when Maplins still traded, probably 15 years back, but maybe more. Bought a “transformer kit” which comprised a set of E & I cores, a pre-wound primary and a plastic former on which to wind the secondary. The secondary is made from 3mm varnished copper wire and was calculated to give about 4 V on the highest range. It’s certainly only a few turns. It has some “grunt”. I operate the button with my big toe.
So far, so good. The jig has survived with the plastic parts intact, and the hornguides are attached to the left hand frame.
however…
this should be easily fixed. Wait for the next exciting installment!
thanks, I hope it works as well for you as it did for me,Just so you know.... I'm pinching this idea for jigging frames and rods![]()
