Dog Star
Western Thunderer
With you working in 1/64th and Mickoo working at 1/43rd... are the waste bins sized to suit the scale?I just tipped out the basket and counted thirty-six bodies.
Jim.
This is where a lump of mild steel and a mallet helped me with the bunker on my MW class F. Some input is to be expected to add defects, maybe a cigarette lighter for a print?I don’t think it’s reasonable to try to pass off a defective model as an accurate portrayal of a defective prototype - unless you’re absurdly lucky and they are both defective in precisely the same way!
You appear to be generating a good selection of parts for a scrap yard diorama!!The other one looks great all round, but the end nearest the build plate is distorted again![]()
Thanks Michael, already done!Simon,
you could taper the flanges a little bit. I assume the distortion at the flanges comes from swelling of the cured resin. A broader base of the flanges cold reduce the effect without being too visible.
Michael
“ The weather is perfect for modelling, but Sunday morning inertia has not yet evaporated…”
Possibly the same with the angle irons. The good end is printing up from the main body. The wavy end is starting in mid air...Thinking about this, I think I’m wrong: Its not that the resin needs to flow away.
The reason you need the supports is because it’s a watershed. Mmmm. More pondering required.
