This weekend's endeavours was the build of a Parkside NBR 4 plank open wagon with side doors.
A look through Tatlow volume 3 revealed that these wagons came as 3 and 4 plank, fixed sides, drop sides and the side door versions which is a nice amount of variety - and prompted me to make a start on the body of drop door version. My idea is to buy some set of underframe sprues from Parkside (and perhaps some buffer sets). The kit itself is a nice kit if a little basic which works for me - again Tatlow revealing more details to be added from plastic strip etc.
The rope hooks are made from some brass pins that I bought a few years ago that have odd shaped heads. Odd shaped in the the heads are lop sided and no amount of turning will make them round and sat square on the ends of the pins for use as bolts or rivets etc. A recent experiment had me annealing the head, then squashing it in a pair of smooth jawed pliers before drilling a hole in the end and using them as eye bolts. In this case a cross pin was soldered in to give a representation of the rope hooks. I also carved off the moulded horse hooks and added a piece of bent wire.
The chain and pin for the brake lever guard are made from plastic rod/fine brass wire - again the end squashed and cross drilled. What is interesting is that on many of these wagons the chain is attached to the lever itself at one end.
More plastic strip was added for the top capping.
And finally a couple of shots of progress on the dropside version
