The chassis has a panel stamped in to inform the builder which end to fit the dynamo and associated bogie. However, when building the brake 2nd, the dynamo is fitted on the opposite end. So the sole bars and central girders need to be turned through 180 degrees.
The sole bars went on without any drama, although I took around 20 mins on each one. The instructions say to fit them on a flat surface, but I found it easier to tack solder to the buffer beams, then pick it up and work my way along. Probably not the cleverest way to do it, but it worked and the chassis is flat and true with no daylight sneaking through the joints. The centre beams literally fell in and soldered up perfectly. I did cheat and fit the additional brake parts first as it looked a bit tight to get them in after the beams were fitted.
I'm a tad disappointed with some of my soldering and a couple of joints came apart due I think to using too small a bit on the iron, but it is tight in places to get the iron in and difficult to clean up.
The nuts supplied for the bogie support plates are steel, and as always, I used my micro torch to solder them on.
There is still a fair bit to do on the chassis, but I couldn't resist positioning it on the bogies
