Just a quick update on what has been happening with the layout. I essentially took a break and worked on getting my stock working. I did have an attempt at finishing the Class 08 but that has been a failed project overall I'm afraid. I finished what I could to practice and I've attached an image below. The issue in the end was with the 3D printed cosmetic chassis provided by the association. I think mine had warped over time and wasn't treated so I just couldn't get the clearance on the wheels.
There are small changes made to the layout in the meantime, I ditched the idea of the buildings in the previous post because I just couldn't get it to look better than the 2 "temporary" buildings I knocked up. I have started to put a retaining wall in and secured the bridge and completed the road. I'm not happy with the paving and that will be revisited, only basic base coats of paint have been applied. I've filled the expansion lines in the yard somewhat as they were far too pronounced and the paint there now needs muting.
The crux of the problem with my builds is I've never have a enough space or light to work effectively so I'll be addressing this over the winter so the layout has been moved from the spare room and I'll be converting the garage into a space where I want to spend time. Insulated doors are on order and by next summer I should have completed the semi-conversion. In the meantime I've used the spare room to repurpose the stand into workbench where I can focus on stock, buildings and anything else that takes my fancy.
The layout itself will benefit long term I'm sure of that.
