Well it finally happened
, after just getting the usual bills and assorted crap from the postman today saw a pair of these delivered, Maxon 6w motors fitted with ABC twin stage gearboxes along with the delrin chain and sprockets,
Only one pictured as i had already started before remembering to take some pictures.
Having looked at the built up bogie it was obvious a slot had to be cut out from the top surface which was relatively easy then a method of securing it all had to be devised. As the gearbox can swing around the axle if unsecured after much scratching of head a real hi-tech solution evolved.........
A bracket soldered to the top of the bogie followed by a cable tie, not as hard fitting as nuts and bolts but secure, simple and easy to remove in the future, remember i only have to stop it swinging on the axle.
Next came the gears and delrin chain, pretty uneventful and luckily just enough clearance between the gearbox and the bearings.
Sorry for the picture quality but i hope they show enough detail.
After this the underfloors were modified for the delrin chain run, and the outer frames bolted back on,
Finally power was applied just to make sure it actually worked, and i am happy to say it turned over like a dream, a testament to the quality of the kit manufacturer Fred Phipps, Mark Wood's wheels and axles and the motor/gearboxes from ABC Gears. I am a happy bodger this afternoon
, cheers Rob
