The Heybridge Railway, 1889 to 1913
James Spooner
That’s looking lovely Richard, but the real thing might work better if there was a flue up the chimney to enable the steam and gases to escape. Maybe drill a hole a little way up each part of the chimney to give the right effect?
Nigel
RichardG
. . . a flue up the chimney . . .
The lack of a flue has come from me changing my mind partway through. I mean, the original idea was to cover the base of the chimney with a tarpaulin, and then I decided to include the hinge to fill a gap so the chimney appeared to be attached to the loco.
I can put a wooden bung over the smokebox part, but I think I will have to go for some very matt black paint on the chimney part. If I drill out the steel pin holding this together, I fear it will drop to pieces.
RichardG
The towing bracket looks too low in any scale. It came off with the piercing saw, though I suspect it was held by just one of its pegs and the paint.
I have trimmed the bracket and glued it back with a fresh pin, another scrap of n/s wire. And removed some surplus rivets.
The two handwheels are a bit chunky so I have slimmed them down.
Clearly, some etched handwheels and slimmer columns would look better . . . but somehow I have got to remember the nature of this model. If I look closely, I can see a slot for a steering column for left-hand drive. There is no firebox door, nor any brake gear. I can only go so far with improvements, though I am rather encouraged to see what I can do with a diecast model. The nameplates will take around eight weeks to arrive. It might be best to put this model aside and come back to it then.
mswjr
I collect these corgi traction engines, the slot either side in the firebox is for a RH or LH engine, So you will have to fill one side, The wheels should just pull off, they are just pushed on a 2mm steel rod, no serrations on it just smooth. And i paint the ashpan a rust colour s they are always rusty.
RichardG
. . . So you will have to fill one side, The wheels should just pull off, they are just pushed on a 2mm steel rod, no serrations on it just smooth. And i paint the ashpan a rust colour s they are always rusty.
There is a pattern emerging here:
1. I do some modelling, and people click the “like” button.
2. I announce that the model is finished.
3. Some of these people point out the more major deficiencies in my efforts.
4. I go back to step 1.
I’ll call this the Western Thunder Effect, though maybe it already has another name. Eventually I escape from the loop, invariably with a better model, and start something else.
The hind wheels twisted and pulled off after applying rather a lot of force. The rear axle is knurled on at least one end, so perhaps Corgi have “improved” their design. Really, these models are made to a higher standard than some model railway stock.
The flywheel came off eventually as well.
I have found colour photos showing tyres of much the same colour as the Corgi ones so I am going to leave these alone.
This is almost entirely the original Corgi model. I have added a length of brass tube and a washer, and tweaked some details.
Obvious omissions are the steering gears, brakes, and the strapping which connects the towing hitch to the frames. Still I think the result looks more convincing on the layout than the original 1:50 scale model, especially when placed as a load on a wagon.
I am expecting the nameplates in late June.
mswjr
Great job, just one last bit if you can do it, Fill this cut-out in, Corgi have done it as this locates the feast crane bit, But on full size this would be a whole plate and the coal door would be on the bottom near the floor, Other wise the coal would fall out as the coal would be filled right to the top.
Garry
Yorkshire Dave
At the end of the day it's just another alloy product to use as a starting point to fettle with, alter and/or add as much detail as you wish in order to bring the model up to your standards.
I use 4mm diecast buses as starting points and my aim is to remove the toy like nature by stripping, repainting. adding missing panel lines and detailing to bring them up to my modelling standards to represent vehicles I have seen or photographed. More recently I've chopped up two diecast Bristol single door RE LLs in order to create one dual door variant.
RichardG
The selection of diecast road vehicles suitable for my period is (understandably) quite limited. Corgi also do Burrell and Garrett locomotives in 1:50 scale, and if I try again I might go for one of these with a new chimney for 1:43 scale and a repaint into unlined black. To stand on the layout not as a wagon load. There are also some 1:43 cars and I must remember these as possible donors when I make my Bentall car.
If I allow my NER low machine wagon onto the layout at all then this has to be in 1913, the year the wagon was built and the year the line was dismantled. This is after the line officially closed, and into the reign of George V. So let the line go out in style, with a movement of a beautifully painted road locomotive heading for export. I will suppose it is going to St George's Island, from Yes Prime Minister, and so 'Deborah' will never be recorded again.
RichardG
I suppose standards are the reciprocal of compromises, or at least they are inversely proportional to each other. My Fowler loco will always be a great big compromise: a 1:50 scale B6 reworked to make it pass as a 1:43 loco which probably never existed quite the way I have portrayed it. The bar is pretty low, because there are details like the spud tray which is out of place unless the model receives slatted tyres.
I haven't worked up the courage to remove a front axle assembly from these models. If I knew I was going to strip and repaint, I might be more ambitious.
Ian@StEnochs
Your engine could have been on strakes, with the spud tray, when new and fitted with rubbers later. Easy just to leave the redundant tray in place.
Traction engine builders offered a range of 'classes' of engine but as most were sold singly to users it is very unlikely that two of the same were identical in service. Quite different to railway engines where every one of a class looked the same. Mostly!
RichardG
Sitting in sumptuous GWR third class accommodation at Hampton Loade this morning I was pleasantly surprised to see D1015 Western Champion draw alongside.
These were the first two trains of the day, with us travelling north and the Western heading south.
Doh!
This was around 12:48, with us travelling south and the Western heading north.
( Diversion : herding sheep at Spetchbury Halt )
RichardG
We went to the model railway show at Highley yesterday. One of the layouts has a working diorama of a sheepdog herding a flock of sheep, which seems well worth a couple of photos.
I have never seen anything like this before in a model. The mechanism is motor bogies running on N gauge track underneath. The sheepdog and the sheep are running on different tracks, so the result is quite a spectacle.
The layout is called Spetchbury Halt and is in 7mm scale.
I found a video here:
NER class H2 . . named as 'Quintus'
RichardG
The rear coupling will obstruct the body fixing screw above it. If I had been paying attention I could have rectified this when I cut my new frame spacers. I want to run the loco for a while, and then add the coupling when I expect the body is there to stay.
I have returned to my ex-NER H2 to complete the model.
For the problematic body mounting screw, I ended up cutting a deeper slot into the head and then turning down the head; and also slimming down the top of the coupling hook.
The blue paint ended up with tiny surface flaws (mostly dust) which don't show up in my photos but annoyed me. So I waited three months for the paint to harden, and then removed them with 2,000 grit wet and dry paper and a little T-cut. This has left a patina on the finish, which again does not show in my photos but I find quite pleasing.
So with the paint repaired, I added the nameplates. These are from Light Railway Stores, and fixed on with CA glue. The Vallejo paint is already rubbing off some edges from normal handling. It has excellent coverage but it doesn't wear very well. So I will call the model "finished" now, as it enters its life of running and maintenance :drool:
'Quintus' represents the fifth loco to run on the Heybridge Railway. It supposedly ran from 1907 onwards, alongside 'Blackwater' and 'Heybridge'. Also the two foundry locos, 'Nellie' and 'Lady Marion', and visitors to the line. I have put coal in the bunker but half-way down so you have to look for it.
This is my fourth loco build. I feel I have achieved a few things here - a decent alignment of the brake blocks, and widened frames with dummy inside motion. Also the paint job is bearable. I mean, the paint is not brilliant but it hasn't ruined the model. And everything is my own work.
RichardG
There is a huge satisfaction in being able to say that.
Yes there is. I made this loco, and if it goes to a show along with Lady Marion then I will be showing models I have made myself and not models I have chosen to buy. Furthermore, I will be happy to own up and say it is mine.
Out in the garden in full sun. This lighting is more critical than the studio flash behind its soft brolly.
It's funny what a photo can show up. If I can wash away the blue rinse on the running board, I am half way to a weathered finish.
Incidentally the model should have brake hoses but they get in the way of coupling up. I suppose, a future task would be to make them detachable in some way.
(Edited to improve the white balance)
