The Heybridge Railway, 1889 to 1913
NER class H2 . . painting
  • RichardG
    Western Thunderer
    There are so many detail posts on the progress of ‘Quintus’, here are two photos of the model as now built.
    Four months on, I have got the painting of the ex-NER H2 underway.
    When I bought the kit I was in two minds whether to build it as an H2 or as some kind of freelance variant with an open cab. After the experience of ‘River Pant’ I settled on an H2, to represent a visiting locomotive. This would get a pro paint job in lined NER livery.
    When the build got underway I realised the kit will not build any of the three NER prototypes. There were variations in sandboxes, steps, brakes and tanks, and the kit provides a permutation which doesn’t quite match up with any of them. So I decided it is best for me to imagine I am building a fictional fourth member of the class.
    Such a loco clearly never ran on the NER, and this gives me a free hand with the livery. Logically it might be black to match up with ‘Blackwater’ and ‘Heybridge’, but I think an Oxford blue will suit the loco so this is what I have done.
    Body primed (U-Pol Acid #8), then masked for body colour.
    The sides didn't receive enough paint so I masked them again and topped them up.
    The cling film is my own idea though I expect other people are already using it.
    Masked to brush paint the running boards.
    The red inside the cab is my undercoat for the scrumbling used by the NER.
    This operation has consumed ten consecutive days:
    0 primer (20th February)
    1 brush acrylic (Vallejo) inside cab and onto buffer beams
    2 mask
    3 spray blue enamel (Precision)
    4 mask, spray more blue enamel (Precision)
    5 wait
    6 wait
    7 mask, spray black acrylic (Tamiya)
    8 wait (probably unnecessary)
    9 mask, brush detail areas (Vallejo)
    My use of enamel followed by acrylic came about because I already had the paint. I haven’t had any problems with the different chemistries reacting with each other, but I did take a few days off to let things cure.
    ( Diversion : painting parts to look like brass )
  • RichardG
    Western Thunderer
    The subject of painting parts to make them look like polished brass came up in a private conversation and I think a photo is worth sharing here.
    This is a painted white metal casting and two offcuts of brass tube. One offcut dull, the other polished.
    The paint is AK Xtreme Metal "brass", brushed on over Tamiya fine surface primer, left to harden and then burnished with a cotton bud. A mate has tried a buffing wheel on a similar casting before starting. I could try this next time.
    For comparison, the brass colour on the insides of the cab windows is Vallejo 70.996 "gold". This looks okay on small areas.
    I think I have a fair representation of dull brass, but polished brass is still evading me. Clearly I could buy a posh component made out of real brass, but if you aren't careful a set of such parts costs as much again as the kit.
    Finishing off the H2 is going so slowly the thing is gathering dust :rolleyes:
    . . power and radio control
  • RichardG
    Western Thunderer
    I have made a start on wiring up the NER H2 . . .
    The loco is receiving seven NiMH batteries, these ones are two-thirds AAA size and branded ‘Digimax’.
    Choosing NiMH technology removes the worries associated with LiPo, and I can use the charger from my similarly-powered Y14. I have a feeling, 400mAh is plenty of capacity to drive the incredibly efficient motor in the Slater’s SG38.
    Test running has shown, with the seven batteries partly charged as supplied (8.4 volts off-load), the loco can reach a scale 23 mph. This seems just right to me, which is fortunate because shoe-horning in an eighth battery would be difficult if not impossible. Charging the batteries takes this up to just over 9 volts.
    The batteries are in three groups, one for the boiler and one for each side tank. The ones in the side tanks are short enough to leave room for a power switch on one side and a fuse on the other.
    I have gone for one fuse for the whole battery pack. I expect some experts will tell me how potentially dangerous this is but to be honest, I think an open circuit is far more likely as a failure mode.
    Thinking about only single fault conditions:
    • the charging socket connects the negative side of the battery pack to the metalwork of the model, and so a short circuit across the entire battery pack is possible in the wiring outside the battery pack or in the r/c board.
    • a short circuit within one group of two or three batteries needs the factory insulation around an individual battery to fail. This is unlikely, because the heatshrink prevents movement and chafing.
    So this is a 3 amp fuse, large enough to never blow in normal operation and placed here as a last resort to save the model before a fire gets underway.
    Here are most of the electrical parts to be fitted into the model.
    The charging socket is the first part to be fixed into place. This is an interference fit into the chimney, and it is now there forever unless I choose to destroy it by taking it out. I don’t like this sort of approach to assembly but there is very little free space to play with. Putting the socket here is easier than putting it in the coal bunker because the wiring ends up where it is wanted.
    The power switch had to be wired up before fixing it into the model, this is fast-setting epoxy glue. Thanks to @simond for the suggestion to put the switch here, the result is going to look really neat yet still accessible and easy to use.
    Here are the power switch, the fuse (opposite the switch) and all of the batteries. What seemed like a huge empty space is getting filled up. I have enough room for the Micron MR603 receiver or the motor, but not both. So the assembly pauses again while I await a smaller receiver, this will be the Micron MR601.
    In the meantime I have a temporary lash-up so I can give the loco some test runs.
    I have touched in the paint along the edges of the running boards! These are now enamel, the Vallejo acrylic was just falling off through handling the model.
    GER 14-ton machinery wagon (1886)
  • RichardG
    Western Thunderer
    The railway needs some kind of implement or machinery wagon to carry a motor car. Last year I bought a kit for a GWR Serpent as a quick and easy fix, and spent most of January trying to build it before giving up.
    Afterwards I discovered that D&S Models do a kit for a GER 14-ton machinery wagon to diagram 25. This wagon is more substantial than the railway needs to carry a mere car, but it is a step in the right direction. It could easily carry a threshing machine instead, perhaps for an agricultural show I still think about modelling.
    These wagons were built in batches from 1886 onwards, and the design must have been successful because some survived into BR days.
    This is what you get in the kit, along with a sheet of instructions.
    At a glance, I can see that none of the parts are numbered or labelled. There are etched loops here to make the lashing rings (good) but nothing to secure them to the deck. There is provision to add springing to one of the axles but no material to provide the actual spring. There are no couplings, and the buffers are solid white metal.
    My first impression is that this kit builds a model a little more sophisticated than the NER Lomac from Connoisseur Models, but the instructions are much more basic. The NER Lomac is of course the first etched kit for countless modellers, including me!
    I have read through the instructions and it is fairly easy to see how the designer expects the kit to go together. There are photos of these wagons in Tatlow, and so I feel happy to make a start. I am determined, this model will not go the way of the Serpent.
    ( Diversion : a traction engine as a load for a wagon )
  • RichardG
    Western Thunderer
    For the record, here is the model without any ballast weights.
    Going back to the suspension . . . I can add some pieces of sheet lead underneath the model, perhaps 80 grams or so. This will give me live springing on an unloaded wagon.
    But! A white metal model of a traction engine is going to weigh most of 300 grams (thanks to @Osgood for this depressing fact!); and even the static boiler I built a while ago weighs 150 grams. Either of these loads is going to make the suspension bottom out; but if I remove the sheet lead and arrange the boiler with care, I can retain the live springing.
    And so, my thoughts turn to making the lead weights removable. Perhaps a turnbutton to hold them in. The trouble is, I have never heard of anyone doing this before. When I "invent" something, I usually find that either everyone else already does this or it isn't terribly useful. I know I can do this, but I do welcome thoughts on whether it is sensible.
    ( Diversion : Middy steam on Easter Monday )
  • RichardG
    Western Thunderer
    Some photos from the Middy on Easter Monday. The Hudswell-Clarke 'Illingworth' was enjoying its last day of public passenger service, it goes out of ticket today.
    The loco carries its usual name on the other side.
    I dread to think how the AI bots will interpret these two photos in years to come.
    Taking a break at Dovebrook after changing the loco on the train.
    This was the second day of public passenger services to Aspall. The station was completed just days before, but is currently landlocked. You can leave the train but not leave the station.
    Fowler road locomotive - chimney detached
  • RichardG
    Western Thunderer
    On the bright side, Corgi do a 1:50 scale showman's engine and one of these has just arrived.
    The top of the chimney is a scale 13 ft 5 in above rail level - right on the limit of the loading gauge. Yet the model is 15% undersize.
    I have had a go at the Corgi model of a Fowler showman’s engine to make it into a road locomotive.
    The model is to 1:50 scale. If I view it as being 1:43.5 scale, the headroom under the canopy is a bit limited but there is a more compact road locomotive hiding inside.
    So here is some modelling by subtraction. It was usual for the chimney to be detached for carriage by rail so this is what I have done here. The surgery is awful but the tarpaulin hides everything. The original chimney is unusable but I can think about this if and when the model gets chained down onto a wagon.
    When I remove the canopy I will reveal an empty space where a scale model would have its connecting rods and valve gear. I could have a tarpaulin to conveniently cover this!
    Contrary to my first impression, there is a representation of the motion in the castings.
    I have repainted as much of the model as I can, but the yellow wheels are difficult to alter. I wish I had bought a model with a less flamboyant livery.
    When I was young, my father had a fabric tarpaulin with metal eyelets around the edges and it was green. Thus I have always thought of tarpaulins as being green but I guess they were other colours a long time ago. If Edwardian tarpaulins were never green I do hope someone will tell me.
    Incidentally, the Corgi model currently weighs 300 grams, much the same as the kit from Duncan Models.
    The modified engine weighs 200 grams. This is still far too much for the springs in my GER machinery wagon, but my NER Lomac has a rigid chassis and seems suitable to carry a locomotive from Leeds to Essex.
    The NER Lomac entered service in 1913, the year my railway was dismantled, so this working must have happened during the months after the official closure of the line.
    Swapping out Dinghams for 3-links
  • RichardG
    Western Thunderer
    I have done a little re-balancing of my wagon fleet. The Brymbo wagon jars in my mind. I am pleased with the brake gear but somehow, the combination of unprotypical model and distant operator seems that bit too wrong. I would probably keep it if it was a better model or a more local owner. At least I know what I did to the brakes, the photos are on WT, and I could do similar rebuilds to different models.
    I said goodbye to my GWR Hydra a while ago. This was a scale model and suitable but I couldn't devise a sensible load for it to bring to the Heybridge Railway. So I suppose I am doing fairly well if I have built 14 wagons and only let go of one.
    I bought some 9ft sleepers from a modeller in Devon and discovered he wanted to downsize his GER collection. So I could hardly resist these . . .
    According to Tatlow (LNER wagons vol.1 p.188), the GER built 3,000 four- and later five-plank wagons to diagram 16 during the decade to 1895. So this model fits my the layout perfectly. I have a Mystery Load too, if I try using playing cards for operations.
    I don't know about the drop side wagon yet. Studying Tatlow, it looks as though these didn't make it into the LNER. But drums of electric cable could be making their way to Bentall's factory or, via the navigation to Chelmsford.
    The GER painted these wagons slate grey and this is usefully different to the greys of the wagons belonging to the Heybridge Railway. Thank you Peter.
    As far as rebalancing goes, I now have three GWR wagons instead of four, and three GER wagons instead of one, and I have gained two absolutely beautiful models to do this. Good.
    Two years ago I bought two scratchbuilt wagons with Dingham couplers. After I pulled off the Dinghams and put in 3-link hooks, the wagons would rarely couple up to my other stock and never to each other because the buffer heads are set too far forwards. I guess this helped to make make a train look better, with the Dinghams holding wagons further apart than usual.
    The buffer stems are set rock-solid in their stocks and I have wanted to do something useful without altering the original wagons. I have ended up putting short lengths of 1mm wire through the hooks, so the hooks and their chains sit that little bit closer to the faces of the buffers. I think this is reasonably in keeping with the models, and better than fitting some over-thick coupling base plates.
    Anyway, the roping on this wagon is far too good for me to undo it to change the buffers.
    Fowler road locomotive - chimney folded
  • RichardG
    Western Thunderer
    I've done my repaint!
    No, the money from the showman's engine has gone on another 1:50 Corgi model, a Fowler road locomotive. I don't know what I was thinking of when I bought the model with yellow wheels. My palette is invariably red, grey and black, with occasional blue for a couple of railway locos.
    Viewed as a 1:43.5 Fowler, the chimney is a bit short but (unlike the first loco with a canopy) it does fit within the loading gauge.
    If I add a driver, the chimney looks short (is he driving a 9 inch scale loco?) but I will need courage to take a hacksaw to this one. Though I'm sure the prototype would fold down for transport by rail. Suppose I remove the "Super Lion" and add some etched plates over the gilt-coloured rectangles, this might be enough.
    Cassette-based fiddle yard . . part 4 new base module with shelf
  • RichardG
    Western Thunderer
    The electrical connections are the same as on my other cassettes. I didn't show how I took the wires from the terminals to the rails, so this is how I did them.
    Four pre-grouping wagons (plus brake) are likely to make the longest train on the railway.
    I have a functioning fiddle yard. Two "short" cassettes (far left) match up with one "medium".
    I am a bit surprised how flat the modified cassette sits on its baseboard. If warping occurs, I can think about fixing some aluminium strips along the sides.
    The fiddle yard has turned out to be a bit cramped (photo in October 2024) and I am making a new one to use the same cassettes.
    The new fiddle yard is a reversible design, for use at home and at a show. The layout connects to either end, so the open side of the fiddle yard can be at the front of the layout or at the back.
    There will be a display board for exhibitions, a shelf to hold cassettes and stowage for r/c handsets.
    The basis of this is a kit from Grainge and Hodder. I have dispensed with the cross-braces supplied in the kit because I don't think they will achieve anything useful in this application. I have put in the diagonal brace instead, to stop the long sides moving relative to each other.
    The brace going under the baseboard had to go in through a hole in one side. This is now blanked off.
    I have taken photos to show parts of the structure before I add the display board. With triangulation in two planes the whole thing is very stiff and shows no desire to settle on a skew.
    The short lengths of oak are a shelf support and something to hold a lighting strip.
    A mock up before I add the display board and fix the shelf, with the unmodified Corgi road locomotive for continuity.
    I want to think I could eventually add further stub tracks so I can use this creation for other track gauges. Especially my H0 and H0e models because I have no workable layout for these at the moment.
    Fowler road locomotive - chimney folded part 2
  • Yorkshire Dave
    Western Thunderer
    I think the most glaring error in the model is the colouring of the tyres. These are made out of soft, pliable plastic. If I can't paint them, perhaps I can make replacements from styrene.
    Could you use permanent marker pens to colour them assuming there are suitable colours available?
    ( Diversion : herding sheep at Spetchbury Halt )
  • RichardG
    Western Thunderer
    We went to the model railway show at Highley yesterday. One of the layouts has a working diorama of a sheepdog herding a flock of sheep, which seems well worth a couple of photos.
    I have never seen anything like this before in a model. The mechanism is motor bogies running on N gauge track underneath. The sheepdog and the sheep are running on different tracks, so the result is quite a spectacle.
    The layout is called Spetchbury Halt and is in 7mm scale.
    I found a video here:
    NER class H2 . . named as 'Quintus'
  • RichardG
    Western Thunderer
    The rear coupling will obstruct the body fixing screw above it. If I had been paying attention I could have rectified this when I cut my new frame spacers. I want to run the loco for a while, and then add the coupling when I expect the body is there to stay.
    I have returned to my ex-NER H2 to complete the model.
    For the problematic body mounting screw, I ended up cutting a deeper slot into the head and then turning down the head; and also slimming down the top of the coupling hook.
    The blue paint ended up with tiny surface flaws (mostly dust) which don't show up in my photos but annoyed me. So I waited three months for the paint to harden, and then removed them with 2,000 grit wet and dry paper and a little T-cut. This has left a patina on the finish, which again does not show in my photos but I find quite pleasing.
    So with the paint repaired, I added the nameplates. These are from Light Railway Stores, and fixed on with CA glue. The Vallejo paint is already rubbing off some edges from normal handling. It has excellent coverage but it doesn't wear very well. So I will call the model "finished" now, as it enters its life of running and maintenance :drool:
    'Quintus' represents the fifth loco to run on the Heybridge Railway. It supposedly ran from 1907 onwards, alongside 'Blackwater' and 'Heybridge'. Also the two foundry locos, 'Nellie' and 'Lady Marion', and visitors to the line. I have put coal in the bunker but half-way down so you have to look for it.
    This is my fourth loco build. I feel I have achieved a few things here - a decent alignment of the brake blocks, and widened frames with dummy inside motion. Also the paint job is bearable. I mean, the paint is not brilliant but it hasn't ruined the model. And everything is my own work.
    . . at NEEGOG (9 May)
  • RichardG
    Western Thunderer
    'Quintus' has finally run at NEEGOG in a self-contained sort of a way, without needing a service wagon to carry its batteries and control gear and indeed with paint.
    The lighting here is a mix of daylight and fluorescent tubes. I will stop whingeing about my paint job, its only my better camera which brings out the faults.
    The red light is from the LED on the Micron receiver. It's one of those things which I probably ought to hide, but will doubtless find essential as soon as do. It is not (as someone suggested at Albury) a firebox glow. Truly.
    After a while the batteries expired so a GER A55 took over the train. Somehow, this is quite an appealing consist despite the Decapod being a passenger loco.
    I would never want to own or build one of these but it was good to watch.
    . . battery endurance New
  • RichardG
    Western Thunderer
    A few people have asked me about the life (endurance) of the batteries in the H2, and I have replied I don't really know.
    I do know a couple of things:
    • The batteries became substantially depleted yesterday at NEEGOG, after perhaps two hours total running spread between there and at Albury and on test at home
    • Charging back to full capacity yesterday evening took barely an hour
    I suspect the capacity of the two-thirds AAA batteries is substantially less than the 400 mAh claimed by their manufacturer, simply because the recharging was so quick.
    To keep the maths simple I will say the radio receiver/controller consumes 30 mA, and the loco motor averages 90 mA. These figures are about 10% high to keep my estimate conservative.
    Suppose the loco runs constantly, like at NEEGOG
    • The model consumes 30 + 90 = 120 mA
    • Battey capacity appears to be around 240 not 400 mAh (because 2 hours x 120 mA = 240mAh)
    Suppose the loco runs with a 1:5 duty cycle on my shunting layout
    • The model consumes an average of 30 + ( 90 / 5 ) = 48 mA
    • Battery endurance will be about 240 / 48 = 5 hours
    Suppose I leave the loco switched on and forget about it
    • The model consumes an average of 30 mA
    • Battery endurance will be about 240 / 30 = 8 hours
    Five hours is less useful than the seven hours I predicted, but the one-hour recharge could be helpful. I need at least one more locomotive to provide cover if I want to operate for a seven-hour show, but the railway does now have access to six more locos apart from this one!
    The Micron MR603 receiver offers a substantially reduced power consumption over the MR601 I used here because the board is large enough to hold a more sophisticated power regulator. I had to choose the smaller receiver to fit it into the model.
    Maybe this is useful to someone, though I don't know whether the people who asked me are on WT.
    Experiments with wheel profiles . . part 1 of 2
  • RichardG
    Western Thunderer
    I have been working up some secondhand wheels in my lathe.
    I know, my mobile crane with its S7 wheels (gauged for 0-MF) runs perfectly at ‘Heybridge Basin’ and consistently derails in one place at NEEGOG. The S7 wheels being narrower than a fine scale wheel, and with a shallower flange. I also know of at least four popular flange depths for 7 mm scale: S7, fine scale, coarse scale, and of course Heljan. Maybe I can find a happy medium between the true scale of S7 (0.66 mm) and fine scale (1.0 mm) which will give me a fresh sense of achievement for new rolling stock builds.
    DSC_2556.jpeg I have made myself a mandrel and a pressure plate for my most popular wagon wheel, which is the 3 ft 1 in with split spokes (Slater’s 7120). This exercise has been good for the lathe too after its cleaning and lubrication last week.
    I have taken about 0.15 mm off the tips of the wheel flanges, and touched the edges to remove sharp corners. So the flange depth is now about 0.85 mm.
    There is no overwhelming reason to do this to these wheels except that I can; and maybe I will make a wheel which looks better and runs just as well as the standard product on the tracks I use. Also this is good practice for a Heljan diesel I want to attend to one day.
    This arrangement makes a really good way to clean up old wheels too. Just spin the wheel and press down a piece of Scotchbrite or perhaps something stronger like fine abrasive paper with a trace of metal polish. Much nicer than cotton buds with horrible chemicals.
    I bought a foot length of 25 mm aluminium bar, so I can make plenty more mandrels if this one turns out to be useful. Meanwhile, I have only prepared two sets of wheels. I'd like to see how they run before doing any more.
    NER class H2 . . charging New
  • RichardG
    Western Thunderer
    Starting with a fully-charged set of batteries, the loco eventually stopped after about three and a half hours. I will say, 3 hr 20 min to keep the numbers easy. This suggests the true battery capacity is nearer to 3.33 x 90 = 300 mAh.
    Going back to charging the batteries in 'Quintus', I posted this photograph back on 19th March. I have deleted the photo from the original post because it shows a bad practice.
    The trouble is (or rather, was), the Vapex charger was charging the batteries too quickly and they were getting hot. The true capacity of the batteries is probably around 240 to 300 mAh, and they need a charger to suit.
    It seems difficult to find a suitable charger. The manufacturers of chargers expect a AAA battery to have a much larger capacity. For the time being, I have settled on the Ansmann model ACS48 charger. This senses the number of cells in a battery pack, and adjusts its charge rate to suit, and has some reasonable reviews. On test with a partly-depleted 'Quintus' it delivers about 150 mA reducing quickly to 120 mA. This seems safer. Certainly, the model is staying cool, which is a relief.
    Annoyingly, the ACS48 does not cut out automatically when the battery pack is full. So for the sake of safety, I have charged the model for just shy of two hours. Two hours at 120 mA being my smaller estimate of 240 mA capacity, and 80% of my more likely estimate of 300 mAh. This is not ideal and if anyone knows of a NiMh charger able to deliver around 120 mA and able to shut itself down with a full battery pack, this would be useful to know. If not, I might use the ACS48 with a time switch. Or perhaps a charger designed for a NiMh PP3 battery would work.
    Manning, Wardle "Lady Marion" . . "Poover" battery and terminals New
  • Boyblunder
    Western Thunderer
    Sadly the Ansmann 'Powerline 2' seems to be completely unsuitable for charging 'Quintus'.
    At power-up, the charger sends a series of test pulses to the battery pack, the pulses ranging from about 15 to 60 mA. This pulses continue in a cycle for five minutes, whereupon the charger shuts down and indicates that it considers the battery to be faulty.
    There is probably a lesson to be learnt here. Most AAA battery chargers are designed, unsurprisingly, to charge AAA batteries. If you use the two-thirds AAA battery in a model you are using a non-standard battery and really, you are on your own. I've got a kitchen timer, I can use this with the Ansmann ACS48.
    The Powerline 2 might still be useful - I can buy some NiMh PP3 batteries for my r/c handsets. Maybe convert 'Lady Marion' to NiMh. But I have made no progress in my quest to charge 'Quintus' accurately and automatically.
    Richard,
    I have been using these "Poover" PP3 sized Li-ions with built in USB C chargers https://www.ebay.co.uk/itm/144773411390 for several things and initially found them very useful. Both have now expired after slightly less than 2 years due mainly to lack of charging in the last 6 months I think. I've no idea what the real capacity is, probably not 1200ma. Perhaps you can try one? Just need to extend the USB C socket to somewhere convenient.
    Robin
    Experiments with wheel profiles . . part 2 of 2 New
  • RichardG
    Western Thunderer
    When I started in 0 gauge (summer of 2021), I thought the FS wheel was really quite a crude thing; but somehow I accepted it without much thought and got on with making models. I now know, the ScaleSeven wheel will run perfectly well on 0-MF track, and a model so fitted looks a lot better. But running such a narrow wheel on a tired 0-F layout is likely to bring disappointment.
    I have been looking for a middle-of-the-road wheel profile which will look better than a FS one and still run at on the 0-F tracks at NEEGOG.
    The trolley runs fine on 'Heybridge Basin' but really I thought it would. I am now waiting for some cassette-deck style drive bands to let me try it over a distance at NEEGOG.
    This contraption now has a drive belt. This is a square-section belt sold for cassette players and CD/DVD drives, and it is slightly sloppy. The pulleys have a vee groove with a flat base and 60-degree sides and, more by luck than judgement, they are gripping the belt beautifully. And so, the thing drives itself along. This photo also shows my experimental wheel profile.
    I have rebuilt the superstructure(?) to set the C of G centrally above the pivot on the side frame, and to leave the C of G unpleasantly high. All-up weight is about 200 grams and the wheelbase is 70 mm, so much the same as a white metal wagon. Running speed is north of a scale 100 mph, so I fear I have been perceived as more hooligan than mad engineer, but the speed really only adds to the fun.
    Well, I put the machine on the track at NEEGOG this morning, and it completed lap after lap without difficulty. It ran perfectly in both directions, including the curved legs of two Peco 6ft points in both leading and trailing directions. In fact, it never derailed. This was more than a mere surprise, I was amazed. I expected it to derail at a moment’s notice.
    A better idea might be to reduce the flange to 0.66 mm (the scale height, adopted by the S7 standards) and keep the original tyre width of 3.4 mm. The wider tread giving the wheel as much support as possible when it runs through a 0-F crossing. This is easy to make using the S7 wheel profile tool. It also gives the opportunity to reduce the tyre diameter a little, to improve the appearance.
    Arguably I am doing nothing new. The wheel standards from the Guild state that the fine scale flange can be reduced to 0.6 mm if suspension is provided. But I am staggered that this works so well on a track I have seen to derail so many models. The wheel profile seems to relying heavily on its coning too, because the flanges are so far away from the check rails.
    This is the wheel profile I tested at NEEGOG today, photographed beside a ScaleSeven wheel from Peartree. The test wheel has the same shape but it is the same width as a FS wheel.
    RG7 would seem to describe the standard you seek.
    I don’t have a big enough ego to call this RG7, but what it is seems to fit the bill for future wagon builds on my mixed 0-F and 0-MF Heybridge Railway. It is also very easy to pull the wheels apart on their axle to create a wagon compatible with ScaleSeven, for when I have a layout run such a wagon.
    The testing has all been rather satisfactory.
    Wagon wheel to run on 0-F, 0-MF and (regauged) S7 New
  • RichardG
    Western Thunderer
    Rather encouraged by this test running I have made four “production” wheels for my next wagon build.
    Minor attempt at creative photography. No problems with Slater’s choice of steel.
    This time I have put a tiny chamfer on the outside of each tread, I think this makes them look better.
    One thing I forgot all about at NEEGOG was choosing a B2B distance for the modified wheels. The S7 flange is thinner than the FS one, so I have settled on 29.7 mm here. The distance is set by putting a washer behind one wheel. This arrangement negotiates all of the track on Heybridge Basin.
    I have chemically darkened the running surfaces, blackened the outsides of the tyres, and painted the insides. One day I will settle on a standardised finish.
    So I am now set up to build a fresh wagon kit.
    Top
