simond
Thanks Rob,
I tried like that, but with the floor. That was very messy, not doing that again
( Actually quite interesting, lots of semi-cured-not-very-well-stuck-together layers, a bit like an underdone lasagne - don’t ask!)
It would be easy to remove the floor and copy your approach, and of course, the subsequent join lines are in the corners inside, so trivial to hide.
You appear to have about 60 very fine supports along the edge. I’d need about 90, I guess, if we assume the absolute spacing is the objective. They don’t look like Chitubox tapered fine supports, did you generate them in the CAD? I think that might be quite easy to do - indeed, probably easier than the Chitubox approach.
I've spent too long on the ‘puter today, need to do something else, but this might be the way to go. Thanks
S
S
finally look at your delay times, that thick ole resin is still moving once the bed plate stops moving, give it a chance to ooze out and stop moving under compression, by the same token, give it a rest before you yank it off the FEP, poor old model doesn't like being ripped off the second the UV light goes out, it's still solidifying so give it a chance to do what it needs to do, then lift off the FEP.
