OzzyO
Hello all,
I set to and drilled all of the axle boxes 2.5mm (if my idea didn't work I could open them out to 2.6mm) .
This is how I set the boxes up in the vice two at a time, I'm using a length of 5/16" tool steel to make sure that they are square to the vice.
Then a length of 1/4" tool steel across the top of them as well to keep then down on the small lip and then nip up the vice.
Then it was onto counterboring two axle boxes to prove proof of concept. Keep your fingers away from the side of the counter boreing tool as it take a chunk of flesh from you finger.
Before.
After.
Brass bearing loose fitted. Has anyone tried using just the white metal as the bearings? It's used a lot in the big world as a bearing material but with a lot of oil.
The trial fit in one of the bogies.
The wheel set spins OK I'm not feeling any resistance that I could put down to the wheel bosses rubbing on the axle box, but I may just take a scrape off the sharp corners of the counterbore just to make sure.
ATB
OzzyO.
PS. now to go and thread some more chairs on rail and get them stuck down.
Before.
After.
ATB
OzzyO.
