A slight deviation from the production line.
An N10 as they were in their last days ( early 60's ), now relegated to shunter status these passenger tanks had their vacuum brakes and steam heat pipe work removed and fitted with three link couplings.
Richard asked me to repaint this model, which was already finished in NER passenger livery, and this is the result.
After stripping the old paintwork with cellulose thinners I carried out a few repairs including new scratch built steps, a new roof and the bunker filled with coal.
She was given a coat of grey acrylic primer and a couple of top coats of satin black. Transfers are HMRS methsfix for the B.R. totem whilst the numbers, warning flashes and R.A. code are Fox water slide.
The basic weathering was applied with an airbrush using a mix of Humbrol matt black, matt dark earth plus a shot of Metalcote gunmetal. I can't give you % of each colour as I tend to change it as I go often cutting back and then going over it again changing the mix as I see fit.
The upper surfaces received a sootier coat, again a darker mix, more of a very dark grey/black/gunmetal.
Richard had asked for a grimy, unkempt example which is how they were in those days. For reference I used a photo of this loco in the Yeadons book which shows it had primed heavily.
To get this effect and the other staining I dry brush ( small short haired flat brush ) using acrylic's and enamels.
The rod joints/crank pins got stippled with real oil which soaks into the matt paint, this gives the appearance of oil soaked grime. I also stippled some gloss varnish after the oil had dried out a bit over night.
Col.
