Yorky D's Küchentisch: And another one....
Messroom
Yorkshire Dave
Western Thunderer
I required a 'modern' building for my proposed London Transport layout to contrast with the Art Deco/1930's style I intend having. The bothy I built earlier is a tad too early for the LT 'New Works' style.
The result is this laser cut kit I commissioned from BrushType4......
......a 7mm model of the Bognor Regis brick staff mess room built in 1955 by the Southern Region. It's a plain mundane building but will suit my requirements of a 'modern' building in the yard.
The parts - as ever they are well executed and fit together very well. So much so I had dry assembled within 15 minutes of opening the package.
The parts identified and some colour coding added to show the locations of the walls. Mess 01b.jpg
Firstly some items required laminating:
1 Plinth
2 Inner and outer toilet end walls
3 Inner floor
4 Outer front wall and the inner front toilet wall
5 Top step
These were glued with PVA and clamped whilst drying.
The inner floor was then glued to the plinth using the inner sides as a locating guide. As can be seen I also lettered the locations of the wall parts.Mess 04.jpg
The two inner/outer toilet walls were dressed on the ends to ensure the laminate join was not evident on the transverse bricks (stretcher). Mess 06.jpg
The inner toilet window sill (circled here) required it's sill brick mortar joints.Mess 07a.jpg
The inner window is shown here (top right) and the micro saws I used to cut the mortar joints are shown. These are small etched blades designed for the Xacto knife handles. This exercise is a bit academic as the toilet walls will be painted white once the mortar is applied and is unlikely to be seen through the frosted glass! But I know it's there :rolleyes:.... Mess 08.jpg
More to follow.....
Messroom
Yorkshire Dave
Western Thunderer
Earlier this evening I painted the interior walls...
The dado rail was drawn on with a Sharpie black marker pen.
Before painting I brushed the outer walls with a brass brush to rough them up a bit. Then it was on with the base coat for 'Flettons' with an old brush which has shed a few hairs - however these will rub off when dry. I'll let this dry overnight before the adding the brick variations.
For the record the colours used were a varying mixture of Vallejo Basic Rust, Yellow Rust, Red, Yellow and White.Mess 12.jpg
The holes in the rear are for locating the chimney.
Messroom
Yorkshire Dave
Western Thunderer
Some more photos after the addition of the mortar.
Front.
Rear - the chimney needs a bit more work. Mortar will be applied to the outer corners after final assembly.
In this state it looks like it should be on the Salisbury Plain training ground. Mess 16.jpg
Close up of the entrance. The interior of the porch wall will be rendered.
Toilet entrance.
Some random building I photographed to check out the brickwork......:)
cmax
Western Thunderer
Thats very impressive, in fact looking at the toilet entrance, you can just imagine the smell........from within, brilliant.
Gary
Messroom
Yorkshire Dave
Western Thunderer
The next item on the list was to glaze the windows.
I was pondering whether to glaze the frames individually or use one sheet behind the window frame. So as an experiment to help decide I cut individual panes from 0.25mm clear acrylic sheet and installed the panes with PVA.
The window on the left has individual panes whilst the one on the right has a single sheet behind the frame.
No contest really as the window on the left looks more like the metal Crittal windows of the 1950's. Therefore more panes were cut. Those destined for the toilet were 'frosted by' sanding them.
Once the glazing was completed the outer walls were installed to the carcass. Before doing this I drilled some holes in the floor to take the lighting cable. This conveniently passes through the cavity wall.
The corners were 'mortared' in and the inner wall of the front step brick wall was pasted with a mortar mix to represent cement rendering.
Messroom
Yorkshire Dave
Western Thunderer
I intend to install lighting in the mess hut which means it must be furnished....
Being lazy I searched around the t'interweb for 1:43 scale furniture - could I find any..... no. So I trawled around for 1:48 scale furninture and bingo...
I found these from a UK supplier who makes dolls house furniture in 1:12, 1:24 and low and behold 1:48.
So I purchased these...
They are laser cut ply and card kits. I started with the kitchen sink and table. Being small and rather delicate they take some time and unlike Ikea there are no screws left over :) .
There are some item I will have to make namely steel lockers, coat hook racks, stove and Hugh Rinal from the Valleys....
Edited to include the last image through the window.
Messroom
Yorkshire Dave
Western Thunderer
Several hours at the workbench today and not much to show for it....... a dining table, 3 dining chairs, 4 benches and a gas cooker.
This miniature furniture almost takes as long as the full size stuff to build :eek:.
The three dining chairs appear low as they yet to have their cushioned seats made and I also added some fine mesh in the grill pan.
And of course most of it won't be seen..... :rolleyes:
Pencarrow
Western Thunderer
Very nice Dave. Won't be seen but you know it's there. I put things in my buildings as well...not necessarily furniture (particularly if it can't be seen) but normally things to quietly amuse me (and no, not those dodgy Faller figures in states of undress).
Yorkshire Dave
Western Thunderer
Likewise, it's just whimsical at times to have something in the buildings, especially when doors are ajar, to tantalise the viewer.
For the sheer fun of it I also picked up this kit.....
.... a 1970's style television..... from the days before we had cinema size sit in the neighbour's garden to watch flat screen TVs.
And yes, the rear cover does have vents in the top.... :eek: :rolleyes:Mess 55.jpg
adrian
Flying Squad
Stunning - that fine mesh on the grill pan looks very effective - i.e. very fine, consistent and regular. Is it manufactured if so how or sourced from somewhere if so from where? I've a couple of projects where a fine mesh like that is exactly what I'm looking for.
Yorkshire Dave
Western Thunderer
The fine mesh is made by Aber - a Polish Company who makes a lot of etched detail parts for military kits as well as HO railway parts.
This is the catalogue page and you have to look for 'Net'.
Aber
I have dealt with them through their website without any problems.
adrian
Flying Squad
Cheers - The website doesn't appear to have an online shop - do you just email them with an enquiry?
adrian
Flying Squad
Thanks very much for that - I tried the listed UK distributors but they didn't seem to stock the smaller meshes. The JadarHobby site lists them at about £4.80 a sheet. I think I'll get a small selection for stock - you never know when they might be useful. :thumbs:
Peter Insole
Western Thunderer
Dave, all this is just fabulously silly - and I LOVE IT!!!
I must say though, that is a terribly good picture for a set without a huge great 405 lines aerial? Ah no, just noticed; you've got a colour test card on there!
Now if you had a wobbly, fuzzy shot of Fireball XL5 taking off....
Don't worry, there are some folks in white coats coming to collect me shortly.
Pete.
Top
