Yorky D's Küchentisch: And another one....
Yorkshire Dave
Western Thunderer
By the way, did you ever get to the Bradford Industral Museum to see the collection of Jowetts?
Not yet, it's still on the list but the recent weather has hardly been conducive for going out.
Tyres can't be that bad - while the driver has been snoozing, someone has half inched the two inside ones off the back end .
I decided to remove a set of rear wheels to make it into a lighter truck..... ;)
Heather Kay
Western Thunderer
Perhaps a little overdone, but for a tired old truck it’s okay. A small but definite improvement. :thumbs:
Now, what’s the plan with the Blitz?
Dog Star
Western Thunderer
What Heather is describing in regard to the wheels being at different angles is a design intention of Ackermann steering.
Often called the 'toe-in' to make steering self-centering.
I believe that the self-centring characteristic of the front wheels comes from the degree by which the caster angle leans forward of the (imaginary) axle centre line..
simond
Western Thunderer
Indeed.
Toe in or out is the non-parallelism in plan view. It contributes to the stability of the steering, but is not the primary reason for self-centering.
Camber is non parallelism in end view, positive camber, as described above, is when the wheels are sitting perpendicular to a normal convex road, negative camber is the opposite, visible to a greater or lesser degree on lots of cars with sporting ambitions. It is used to compensate for the deflection of the tyres in such vehicles. I don’t have any idea why older vehicles used considerable positive camber, unless they used cart wheels, where the dishing is very limited. Ideally you would want the kingpin axis to coincide with the tyre contact patch in the end view, which requires the wheels to be dished.
Caster angle is more easily seen on a motorbike, the forks are typically parallel to, but offset from, the steering axis. Producing the axis of the steering until it his the road allows you to measure the trail which is the distance from this intersection to the centre of the contact patch. The angle effectively means that steering the wheel away from straight lifts the front of the vehicle, so gravity tends to bring the wheels to the straight ahead position. Trail does the same thing.
Sorry, rabbit hole...
atb
Simon
Osgood
Western Thunderer
Here is a Ford Model AA axle - just look at that KPI!
So when a wheel is turned inwards (e.g. RH wheel turning left) the bottom of the wheel will tuck under, and when turned outwards it tucks under.
Interestingly (or probably otherwise :))), positive or negative caster (another factor in non-upright wheels) is usually adjusted on truck axles by means of tapered wedges between axle and spring - with KPI and camber you are stuck with what it is, but the turning effect can be compensated for by the castor angle.
Dog Star
Western Thunderer
After such a lesson in steering ideas, Simon, you shall no doubt enjoy the simplicity of the Land Rover front axle (say SIII ) with:-
* positive camber for the wheel;
* toe-in of variable nature;
* camber for the virtual king pin (actually top and bottom swivel pins);
* camber through the placing of the top and bottom pin bushes in the swivel hub housing,
All in all a neat solution to the problem of going round corners. What has never been explained to me is how the 88" WB and 109" WB steering set-ups are the same since that ought not to be the case given the basis of Ackermann geometry.
Tony, (@Osgood), I did get around to adding king pin inclination into the discussion - at the same time as you were typing. I stopped short of mentioning KPI because of how LR achieved the requirements through the design of assymetric swivel hub - assembling hubs the wrong way converts the KPI angle between negative and positive with interesting effects.
Osgood
Western Thunderer
Same with all those cheap short wheelbase tractor unit chassis that turned into flatbed recovery trucks by doubling the wheelbase!
Yorkshire Dave
Western Thunderer
Tony, Simon, Dog Star - thanks for the detailed information - yet more to store in the old grey matter. I never knew steering was that scientific.
GMC
Yorkshire Dave
Western Thunderer
Following Heather's observations regarding the cab shape on the Opel Blitz I've had another look and it'll be tricky to convert to a Bedford cab...... I'll take the lazy option and build it as Dutch or German civilian vehicle - so some Hauler etched parts are on their way :) .
In the meantime a start has been made on the US 6x6 aircraft fuel tanker.
Chassis - the 'sagged' wheels are from the DEF Model range.
And yes, they are Uniroyal tyres....
AJC
Western Thunderer
There were at least a handful of Opels imported before hostilities commenced - there was a picture of one in traffic in the centre of Bristol (trams and all) published in one of the vintage commercials magazines, recently, but not, I suspect, one of a statistically significant number!
Adam
adrian
Flying Squad
My understanding (which may well be wrong!) is that there were a couple of reasons. For early vehicles suspension geometry was in its infancy and so things were kept simple. As the suspension gets loaded then they would move towards a neutral or negative camber. So when cornering as the vehicle rolls then the outside wheel would load up and move to a neutral camber - making the best contact patch by having the wheel perpendicular to the road. I have also seen comments that the positive camber lightened the steering load, useful in the days before power steering although I'm still try to figure out how that works. I can see how extreme negative camber makes the vehicle very stable in a straight line. You only have to look at the para-Olympics all the wheelchair athletes using significant negative camber. So presumable positve camber works the other way.
simond
Western Thunderer
Yep, another element in attempting to get the king pin axis to coincide in end view with the centre of the contact patch!
again, the dishing of the wheel is relevant.
Atb
Simon
simond
Western Thunderer
vehicles with a beam axle do not change their camber with added load, though the castor angle and trail may change. Vehicles with independent suspension do change camber with load (and dynamically).
I’ll have a ponder about the wheelchairs, though I suspect it may be more to do with the ergonomics of riders’ arms reaching the hand-wheel than anything to do with steering, or cornering stability.
As an aside, in my Mini days, (many moons ago) I fitted neg camber lower arms to the front suspension. It stopped understeering very noticeably. Once it did let go at the front (at much higher cornering g) it was a bit digital, all or nothing, not progressive like a standard Mini. You were not going to get it back unless you had acres of space, or you stopped...
They are dead easy to make if you can weld, or can find a welder you can trust. Chop the lower arms, roughly in the middle. Place a suitable piece of steel, maybe 3-6mm thick between the ends, and tack back together. Check it’s all straight, then weld a couple of 1/4” rods in the web of the arms. The ones I made were about 4” long. I can’t remember the calculation of extended lower arm to degrees of camber, but it wasn’t hard to work out. A few mm makes quite a difference!
Atb
Simon
Overseer
Western Thunderer
The erstwhile Millwall Extension Railway. When I get to the pc I will try and work out which way the photographer is pointing.
Rob
It is the north abutment of the steel bridge across Manchester Road (or is it still Westferry Rd there) taken from what was then Johnson St. The photographer had his back to the North Greenwich station building and the Thames. This was after it closed the first time and the steel bridge was removed. A new bridge was built for the DLR but that has now gone. The brick viaduct survives but unused again since the tunnel under the Thames was built.
Top
