The difference is much more stark when I line it up against the other Sentinel painted in solid black.I presume you sprayed it with Zero paint. The black is quite grey compared with the coal and as such is most attractive.
I was reading about them earlier today on your website ... along with your model of Holywell Town, a few miles down the coast from me. The Avatar's Mostyn. Cheers.Sorry - forgot to say for the benefit of the new members, the Jinty is a Connoisseur model with a few tweaks and the 3F is the JLTRT offering, again with a few tweaks.
www.cherryclan.com
Hi Adrian , there is an alternative to a complete respray and that is weathering. MIG have a product called a an oilbrusher and one of the colours is called ' Starship Filth' . Its an oil based paint and only requires a few dabs on the side of a loco and then brushing out with a flat brush . It will spread from here to the moon and you can keep working it for at least a 1/2 hour which is how long each side took on the pannier . Just a warning, there is another product with the same name ie 'starship filth' in a tube from a german company , this is too dark so will not achieve the same result , actually on a black loco its a complete wate of time .So many many ..... many years (decades!) ago I built a couple of loco's and posted a few photo's on WT. Although the loco's were finished I never got round to posting any photo's of the finished painted items.
There were many reasons for this, one of the excuses is that I was never happy with the paint finish on them so I was reluctant to post photos knowing that it was going to be my intention to strip and repaint them anyway. I kept putting off the repaint job until I was happy that I could make a halfway decent job of it. As it was the Jinty required 2 repaints i.e. it's on it's 3rd paint job now and for a very simple black paint job really sort of inexcusable. The first paint job used a badger airbrush and enamel paints, basically it was a bit of an orange peel finish and too thick losing crisp detail. The second attempt was using cellulose and an Iwata Neo, the finish was better but very patchy an uneven, I also struggled to get any consistency of thinning for spraying. So finally after more changes another upgrade to an Iwata TR2 and using zero paints I've managed to get a finish I'm happy with. I do think the change to the TR2 has helped me in that the trigger is a pistol grip rather than the button on top which is more comfortable and the zero paints already pre-thinned for the airbrush means it's a lot easier to chuck in the airbrush, with a dash of grey added to the black.
Given the results with DCC and sound on the Sentinel I have fitted DCC, stay alive and sound to the 3F, the improvement to the running qualities was marked so as soon as funds permit the Jinty will also be retro fitted with DCC, stay alive and sound.
Anyway enough of the waffle and excuses - just the photo's to present now.
Cheers - that's another "paint job" - the website is well out of date and needs a refresh. Unfortunately that version is built on Wordpress and I've come to hate it with a passion so I don't enjoy touching it at the moment. Too many updates and then trying to make sure the additional plugins haven't broken or need updating is a real PITA.I was reading about them earlier today on your website ... along with your model of Holywell Town, a few miles down the coast from me. The Avatar's Mostyn. Cheers.
I know, I know, fully agree at some point I need to embrace the weathering of my models, but until I have a layout on which to run them then I'll keep using that as an excuse to putting it off. Although w.r.t. the painting I find it easier to make a pigs ear out of a silk purse rather than the other way round. Hence I would like to get the paint looking reasonable first prior to weathering.Hi Adrian , there is an alternative to a complete respray and that is weathering. MIG have a product called a an oilbrusher and one of the colours is called ' Starship Filth' . Its an oil based paint and only requires a few dabs on the side of a loco and then brushing out with a flat brush . It will spread from here to the moon and you can keep working it for at least a 1/2 hour which is how long each side took on the pannier .
They are RCH 2 rib 20.5" buffers, used mainly on vacuum braked vans but also other vacuum braked wagons. David Parkins has some ABS ones on sale described as 'BR Extended two rib fitted RCH buffer set' (product.php) which should be the right ones but I am not certain and buffer heads will be also be needed. They were made in cast steel and fabricated (welded) steel versions which look similar but different.Can anyone point me in the right direction for a 7mm supplier of these buffers, being an ignoramus in these matters I don't know what they are called and the various websites so far visited list various buffers by name but with no photos attached I'm not sure what I'm ordering.
Having virtually finished the locos it was really nice to have a general clean up and make some space on the workbench for the next project.
I decided to switch back to building a couple of wagons, in this case a kit obtained last year for a Palbrick.
There have been a couple of threads previously on WT building these, albeit in 4mm rather than Scale7. So I don't think I'll post many photos during the build, besides which the kit includes a CD with a very comprehensive set of build photos. Hence there maybe an occasional update or posting if I've gone off piste.
Anyway the chassis all folds up quite nicely
By this point there are already 3 layers of etches with the chassis, middle layer and half etched floor so there is already a fair bit of weight to the kit. Once everything is fitted I reckon it won't need any additional weight added.
One question for the 7mm WT modellers - as supplied the kit is etches only so I need to source a few cast components, the first for consideration are the buffers. Unfortunately the recommended supplier is no longer trading so I need to find some that look like this
Can anyone point me in the right direction for a 7mm supplier of these buffers, being an ignoramus in these matters I don't know what they are called and the various websites so far visited list various buffers by name but with no photos attached I'm not sure what I'm ordering.![]()
Hi AdrianOne question for the 7mm WT modellers - as supplied the kit is etches only so I need to source a few cast components, the first for consideration are the buffers. Unfortunately the recommended supplier is no longer trading so I need to find some that look like this
It would good to see any progress on Holywell (says he, inspired by an upcoming trip to the 2FS Diamond Jubilee exhibition) although I understand very well the problem of conflicting demands on modelling time...... along with your model of Holywell Town
