An internet search finds several inns called the "The George" within a couple of miles of Bath. My guess is that you refer to the hostelry in Mill Lane.... corrrect?
Yes that is the one, well suggested by Tim and a perfectly decent Chef & Brewer establishment with good facilities and a lovely canalside disposition as Tim says.
Having put my thinking head on, and if you are open to interesting routes, I have another suggestion:
Another George at Norton St Phillip, credibly one of the oldest pubs in the land and although I haven't been there for a while it looks to have a decent menu and attitude to its customers. To get to it, leave Radstock on the Frome Road A362, turn left on to the A366 about three miles out of the centre at a crossroads after the road has levelled out, travel along this road, through Falkland, until you get to the B3110 at Norton St Phillip, the George is then just to your immediate right as you "give way". You will incidentally, a couple of miles before, have passed
"Tuckers Grave" which is good for cider and antiquity.
If you take this option, after lunch you can avoid travelling through Bath to get to me (and all points east) by re-joining the A366 and heading North East out of Norton (past the
Fleur De Lys, another lunch possibility), crossing the A36 (the junction is laid out safely for this manouvre) and then after about 3 miles (having passed Warleigh Castle) you turn left on to the B3109 and then follow this road into Bradford on Avon (Lovely Brunel station building, loadsa pubs) from where you follow the signed route to Bath on the A363. You may well still encounter a queue (it won't be as bad as the other way, trust me), one wheeze if this is the case is to go past the turning for Bath if it has a queue, travel North for less than a mile and take the (first) turning on the left, signposted Swainswick, which will drop you back down the old A46 which never has a queue at the bottom where it joins the A4. This done take the first available right into Larkhall, if you miss it either of the following two RH turnings will do the same job.
All of the above is a lot easier than it sounds, by the way keep the "old A46" dodge to yourself as its a secret known to locals and dedicated "rat runners"* only
Simon
* A perjorative description to which I do not subscribe, roads were put there to be used. Only idiots, bigotted nimbys and misguided councillors try and force all traffic on to already choked roads.
Sorry for that mini rant
