The result looks very neat and tidy, how have you got the rivet spacing consistent?Tender sides riveted.
I used the etched dimples as a guide, but relied on the rivet press for getting the rows of rivets as straight as possible.
Thanks Graham.The result looks very neat and tidy, how have you got the rivet spacing consistent?
regards, Graham
I hope so too!Mike
The bit to be fitted on the right should cover the gap at the front, I hope.
Richard
Can I ask what the particular make of rivet press you are using?Thanks Graham.
The rivet press has indexed slides for both directions. Once the piece is clamped in place I just wind it in or out and do the riveting. This gives me a straight line of rivets.
I've since managed to form both tender sides. Pic below shows parts just propped in place until I get the courage to start soldering it all together.
Mike
Hi PeterCan I ask what the particular make of rivet press you are using?
It certainly looks like it does the job.
You could have put brackets like MOK did to there B1C tender.There's a couple of cross-members that need to be added to the tender chassis. Problem is that once they've in place it's no longer possible to unbolt the chassis from the running plate. Not ideal from a maintenance point of view. The cross-members are quite noticeable so I don't want to omit them. So I've soldered in some little brackets. These will allow the cross-members to sit on them aided with a small dab of glue or even blu-tak. This should allow easy removal should the occasion arise.
Mike
Far neater than my effort!
