adrian
Flying Squad
Hi Len,
No problem - looking at your screen shot I suspect you have too many items (entities) selected. If you look at the bottom middle it says you have selected 37 entities on 2 layers. For a start all of your selected entities should be on one layer i.e. only on layer 3 half etch outline. As you have layer 4 visible as well I suspect inadvertently you have some hatch object selected on layer 4. So first thing I'd suggest is turn off the visibility of layer 4, that should deselect anything on that layer, then turn it back on again and make it the active layer.
I've put together another short video with a couple of tips with making the right selection of objects for adding the hatching. Hopefully this will give you the info you need to make the right selection.
