This morning's task is to work out the centrelines for the suspension units, and work out the ride height.
The Connoisseur units are neat fold-up things, provided with simple but comprehensive instructions. Two units are for the outer wheelsets, with a slightly narrower unit for the centre wheelset in a six-wheeled coach. This is to allow some sideplay on the centre, which may or may not be necessary for this build.
Note the various triangular and diamond holes, which are designed to help alignment of the unit when fixing to a coach floor.
I do worry that some of my measurement techniques are a bit slapdash, relying on offsets and alignments aided by the Mark One Human Eyeball. Then again, I can't see how I can do it otherwise in some situations. Having fitted the "floor" plates over each axle (they are not actually fixed yet, which isn't helping with alignment issues) I needed to find the vehicle's longitudinal centreline. A length of 1mm brass rod run through the coupling slots on the buffer planks helped, followed up by some vernier measurements.
I suppose it doesn't really matter if the units are a little off centre, provided the wheel sets are parallel across the coach. But that's not the point.
I formed up one suspension unit as Big Jim intended, so I could do some eyeballing for ride height and general orientation. I haven't fitted the sliding bearing surfaces yet, but this crude assemblage is enough for me to see how things fit, and for me to work out how far apart the bearings need to be to suit the broad gauge. This unit will be hacked apart, but the unbuilt ones can be split before forming up.
The ride height isn't a million miles out, but I can't confirm that until the proper bearing units and springs are fitted.
What became apparent is there is
precious little space between the front of the wheel and the back of the axleguards. I do not think there will be any sideplay in the centre axle at all. Future builds will need to take this into account when thickening up the solebars, and this build will need some careful insulation placed to avoid shorts.
After the fairly rapid progress on this build, even allowing for the rebuilding yesterday, I am now finding patience waning and frustration building. I guess I ought to firm up the various mods required on the suspension units before I pack it all away again in favour of another of the growing pile of part-built commissions!
