Over the weekend I applied some brushed weathering around the underframe and bogie sides. I think it needs a little more, but that'll probably be best done with powders. Inevitably, some paint has chipped off the copper and brass here and there. I’ll retouch that/weather it out later in the reconstruction process. There’s bound to be more damage yet.
As you can probably tell by the judicious use of Kirby clips…
… the PCB and wiring loom is back in, and bogie power reconnected. When I’ve cleared the test plank, we shall see if this thing still runs on 12V. The lighting loom needs some careful work, first not to break the thin wires, and second so it is held in place with sufficient slack to let me plug the lights into the various orifices in the noses.
Before the body is reunited with the chassis, though, the driver (not come up with a name for him: suggestions welcome) has to be painted and attached to his seat, and the cab interior parts need to be fitted into the body shell. The original parts were a press fit. The new rear walls may need some additional help.
I have been gathering scrap material to let me make new wipers, and will need to scratch together material for the hand brake linkages and chains. Nearly there. One big push and I would think we will be home and hosed by the end of this week.
Ha! As if!
