O-EM-OO9 workbench - LMS 16t mineral
AJC
Western Thunderer
I have a couple of these - acquired as parts of job lots, I have a notion I may have one on the sprue, too. That's certainly too many, especially as the built-up pair have pressed steel doors - various MoWT types looked similar with the welded doors and they were more common. But they shall be done, when I'm next in the mood for mineral wagons. The 'bench seems to be full of locos at present.
Adam
76043
Western Thunderer
Thanks @Simon H and @AJC
Yes, the next one is the light grey colour. This is what happens when you buy three of them from eBay only to find there's enough parts to do two.
I'm saving the two complete Cambrian chassis for a rainy day as they come with the longer 17'6" option. I have two Parkside double brake chassis going spare so they'll be used here.
Tony
76043
Western Thunderer
The second one is up on its wheels now, welded side doors and pressed ends, with spoked wheels and proper handles on the end door.
There's an LMS one like this in the Acquired wagon series, although you can't see the end door... But rule 1 applies.
Cambrian body, Parkside chassis.
Tony
hrmspaul
Western Thunderer
How common were pressed end doors on LMS minerals. Non I photographed had them, they all had a fabricated end door, rivetted or welded.
Your model is like a very old Farish model I have or had 60 years ago.
Paul
76043
Western Thunderer
Good question, it seems from reading the Acquired wagon series that they got replaced over the years. So there would be a tailing off over an unknown period, this might account for you not seeing any.
So my view for these models is that they would be around in the fifties but starting to be replaced, hence the welded side doors on this one.
Tony
76043
Western Thunderer
Finally got around to cutting the holes in the metal case for my WiFi based DCC-EX command station. Doesn't look much, but the top round power in socket and the green power out sockets needed cutting out and fettling. 1.25mm steel takes a bit of time, followed by etch primer and coat of satin black to make good the damage.
The command station was flashed to the latest version yesterday, so once the paint is hardened off I can tinker with DCC without cracking open the laptop. An old mobile has become the throttle.
Tony
76043
Western Thunderer
Been busy painting my wagons recently, not much to show here as it's just a large tray of painted parts.
However, more work on the LMS mineral. Gussets and brakes, nearly there as the levers have been fettled and ready to glue on.
A package from High Level has arrived...
Tony
Osgood
Western Thunderer
Next up, Peco GWR V14 van, ……
Then paint stripped using my go to Tesco kitchen cleaner spray.
Could you enlighten me further on this product and how you use it please (spray/ soak)?
What types of paint is it good for (or from the paint’s POV, bad for)?
76043
Western Thunderer
I spray it on and leave in airtight plastic boxes such as the ones that take aways get delivered in.
It generally needs 24hrs to start working on acrylics and enamels, then another application if the paint is new, old paint comes off quickly. Does work on all plastics that I've used so far. No good on masak as it leaves a white crystal residue that is almost impossible to remove.
I find it does the job if you have the time.
Tony
Top
