richard carr
Western Thunderer
Work has been progressing steadily over the past few weeks. John Birch has been very busy staining sleepers. I have been sticking the sleepers down, but yesterday managed to start building a bit more track. This is the curve that heads off to the diesel depot and the branch, it is quite tight for a real curve but is in fact a radius of 2.5 metres, so pretty much everything should go round it. It will be check railed so passenger vehicles will be able to pass.
I also decided to add some gauge widening, as the real thing would almost certainly have had some and used the S7 goups green triangular gauges to effect this.
It certainly pays to place some weight to hold things down. These are the walnut sleepers that the S7 group supplied and they are a little variable as to the their thickness, but it isn't that bad, there are though a few that are far too thin or too thick that need to go in the bin.
Every 4th chair is one of David Rayner check rail chairs, it's too expensive to use one for every chair and they need super gluing in place as butanone has no effect on what ever they have been printed in.
Then this morning these turned up
These are from MM1 models so now I need to work out exactly how many of these I'm going to need to do the 2 bridges.
Richard
Richard
