Monks Ferry: a layout for the Grandchildren.
James Spooner
Western Thunderer
I have to say, I’m with Simon on this and think you are being unnecessarily harsh on yourself. I think the whole building is striking and quite believable. If you can sort out the leaning towers (and, let’s face it, the good burghers of Pisa have been living with a leaning tower for centuries), then so much the better.
best
Nigel
jonte
Western Thunderer
Your kind encouragement and welcome advice is not wasted, Nigel, so thank you.
I’ve been thinking about placing an intermediate station at the opposite end of the layout for some time as a point of interest and think this would be ideal (save having to build another :thumbs: ). As the (leaning) towers match those of the terminus, it would make sense as it fits the theme and could be considered a trademark of the SC&ER.
Ive just returned from the model shop with a lighter wallet so my mind is now set on a replacement ;)
Thanks once again for your flattering comments.
Jon
John57sharp
Western Thunderer
I'm glad to read this Jon, the thought of all that work being discarded grieves me! Anyway the good news is that you will be revealing us with lots more updates AND keeping the local model shop going a bit longer!
Cheers!
John
jonte
Western Thunderer
A start has been made on a replacement building, one which more suits the most recent build.
The fascia has been cut to size from the same material and marked out.
The build will be influenced by, although not a copy of, Oxford Road station on the original Liverpool to Manchester railway.
My version of an arched feature window found on the ground floor of the station, although customised with sash windows used for the rear portion:
Still a long way to go.
Thanks for looking.
jonte
jonte
Western Thunderer
My bargain basement take on Oxford Road station continues:
And the real thing:
The painting will be a little more prototypical as this is the sort of finish that springs to mind when I think of an elderly station towards tge end of steam.
Thanks for looking.
jonte
jonte
Western Thunderer
Further work involved cutting an aperture in the frontispiece for addition of sash window to match the others elsewhere:
This took a lot of effort due to the use of thick laminated plasticard, involving different sized drill bits and two piercing saws (my usual one’s frame wasn’t deep enough and in trying to extend it in vain, saw me slip and cut through the elliptical top section which then had to be repaired…..). Then the blade on the second saw, with a deeper frame, broke and I’m currently out of the very fine blades it uses, so I had to finish and tidy using some customised ‘files’ of various sizes honed from emery boards (and one or two modelling ‘metal files’ for the corners).
I’ve also built a door, based on that in the previous post, from various offcuts of section. It was then distressed with a blunt blade and hat pin to give it a worn look. As can be seen below, I attempted the lozenge shaped panels of the prototype however they weren’t uniform enough, so I opted for plain old (tiny) rectangles:
Eventually I’ll finish off with some fabricated handles or simply just use track pins.
The apertures for the arched windows (seen here with tabs fitted to attach to below the fascia) were cut and the windows marked out:
And then placed under the apertures to see what they looked like:
They’ll do.
Next, I’ll cut out the window apertures then laminate the fascia. Then the window surrounds (different from those to the rear) will be fabricated and attached.
Thanks for looking.
jonte
John57sharp
Western Thunderer
I like the way this going. Sympathies with the trials cutting out apertures in thick sheet, mine won’t win any tidy work prizes I’m afraid to say!
Currently very busy in the garden and garage doing Spring cleaning up etc, so no progress!
John
jonte
Western Thunderer
John
Hi John, and thanks for your kind sympathy and show of support as always.
The good thing about modelling aged buildings is that you can always pass off the odd blemish as ‘weathering’ ;)
Don’t be too hard on yourself, John, and reserve your critique until an item is ‘finished’ (if it can ever be classed as such!) as I suppose it’s the overall look that counts.
Cheers.
Jon
jonte
Western Thunderer
Jonte,
When I am having a ‘difficult’ day and the meds are not cutting the mustard, I sit down with the iPad and just browse through your progress, it does me no end of good…..thank you for the inspiration.
I don’t think I could honour this - your kindest of compliments- Tim with anything I could possibly muster, apart from to say, Bless you.
I just hope I can continue to lighten your burden.
Jon
Phil O
Western Thunderer
Jon,
Just been catching up on the last few weeks posts and I'm gobsmacked that you got so close to achieving the station building and then gave up. I thought that effort was outstanding, but this current iteration is very likely to exceed that, I wish my efforts were approaching that good. Truely inspirational, along with Chris's Pencarrow modelling. Following enviously.
jonte
Western Thunderer
Jon,
I’m most grateful of your interest, Phil, and kind compliments.
As for the original building, you just know when something just doesn’t sit right. Still, an intermediate station is required so it will suffice as a stand alone.
Like before, despite using a prototype as a basis, I’m still making it up as I go, which isn’t always for the best as I’ll explain when the piece concerned arrives :oops:
Just hope I can maintain your interest and all those WT-ers kind enough to drop by.
Best,
Jon
Top
