I want to keep the etches wrapped up until I start the build, but in the meantime here is a photo of the other parts in the kit.
All of the castings are in brass, and there are pieces of wood and veneer to make the buffer beams and footplate. Each piece of wire is labelled, as are the bags containing the small parts. The instruction book is printed in colour throughout.
The kit arrived beautifully packed, in a good cardbord box with this enclosed inside a fitted outer transit box. The packaging looked good enough for shipping worldwide e.g. Australia @Overseer if wanted.
So - so far, I am very pleased with my purchase. An excellent first impression![]()
Richard,I have opened the box again! It's nice to let a kit mature for a while, but not too long. This time I unwrapped the etches too, and had a look at the instruction book.
This kit is so very different to the Slater's class F. At a glance, the wrapper for the saddle tank has been etched from some suitably thin brass and has the handrail holes already placed. And there are etched fold lines too! This was the most impossible part of the class F, so if this works then the other parts should be fine. Everything I have looked at so far seems to be here with a view to including it in the model and without sending the builder off to make or buy substitute parts.
I found a High Level 1219 coreless motor, and this happens to be the motor recommended for the kit. So I've only had to order up the Hump Shunter gearbox and the hornblocks.
The kit includes a pair of compensation beams. I seem to have bought the last two pairs of slimline hornblocks in stock at High Level Kits, so maybe Fate is telling me I should be building this with a fixed axle at the back and not CSBs.
I am not chomping at the bit to get started, rather taking in what the kit involves and thinking through how I will go about the build. I wonder if anyone else has made a start?
Then when I got to my laptop they were out of stock! Strange that!
Please John, have you built your own models with a rigid chassis or with hornblocks? If you did use hornblocks, it would be very helpful to know how you arranged the springing or compensation.
Having read the instructions I decided to spring the leading two axles using High Level slimmed-down Hornblocks, and checking on my 'phone there were two sets available so I carried on and cut out the openings for them. Then when I got to my laptop they were out of stock! Strange that!
