Edinburgh Princes St in EM
Phil O
Western Thunderer
Several years ago I tried to scribe large areas with my Cameo 3, but it crashed, so now only use it to do the non standard stuff, like arches and quoins. I use Finecast or Slaters sheet for the rest.
Ian N
Western Thunderer
Hi Phil
i haven’t experienced a problem crashing the cutter, but a file for an A4 size sheet of any of the more common brick bonds is horrendously large ( @15mb iirc) and considerably impacts the performance of my old pc, especially when working with different layer or groups. IIRC, an A4 sheet of scribed brick bond will take well over 2 hrs to scribe. To reduce the impact on pc performance, I have A4 templates for various brick bonds, and draw the walls first, save the file, then start removing any of the template outside the lines for the wall, saving regularly. Having got bricked walls, I then add window and doors and remove the template bricks from them, again saving after every window/ door. Trying to get the file sized as small as possible as quick as possible. In my case it’s trying to get the best out of the limited memory and cpu of the pc.
Where I have had cutting related issue, it’s been either down to the plastic - not consistent in thickness or ‘hard’ areas within the sheet which grab the blade, or the cutting mat - loss of tack through excessive use on silhouettes own mats, or lack of adequate tack when 3rd party mats have been used. The latter failure usually occur with the blade not releasing from the plastic at the end of the cut/scribe and lifting and relocating the plastic from the sticky mat.
Most of the brick structures were commenced prior to obtaining the Silhouette, and all use either Wills or Slaters embossed sheets
Ian N
Western Thunderer
Ian, that really is a superb picture....
Merry Christmas to you and Martina.
Cheers Dave.
Hi Dave
Are you suggesting a sense of deja-vu………? What lottery numbers should we use. But don’t tell everyone
I was anticipating a response to nothing moving with a comment about unfinished wiring. After how many years…….
Until I catch up with you at the club next year, all the very best to Fiona and yourself.
Hope you both have a wonderful Christmas.
Ian N
Western Thunderer
The work of Davy Scott, the first two bits of safety railing have the test fit on top of the small retaining wall. Not very obvious from the camera angle, he has captured both the solid and open posts in the prototype. Made from .5 wire and brass strip.
I’m always amazed at how much a relatively small item can make such a improvement to a scene and boost motivation.
The Transport Treasury image of the actual location
Ian N
Western Thunderer
Further, slightly better, photos of Davy Scott's work on the railing, and a slightly better view of this part of the model and how it interprets the view in the transport treasury link in the post above. Better get that missing broken telephone pole done I suppose, along with the rest of it..IMG_6185.jpegIMG_6187.jpegIMG_6188.jpeg
Dave Holt
Western Thunderer
Lovely work and a very impressive looking layout in progress. As you say, the railings are an interesting feature with good attention to detail.
I wonder what the purpose was in having some posts "open"? They appear to be spaced quite randomly.
Dave.
Ian N
Western Thunderer
Dave.
Thanks Dave. You've raised an interesting question I don't know the answer to.
My original assumption was that they were all solid, then corroded. The "single legged" post in the Transport Treasury image seems to discount that, as I would have expected them all to have corroded at the same rate, so it is unusual in being a one-off.
At the time of the TT photo, they would have been in that location for @55years. What sort of condition would they be in after 55years in an acid rain environment, assuming they hadn't been somewhere else first? Were the solids are the replacements for corroded opens....?
it gets further complicated, if you go the other side of the bridge, where the height difference between the goods and passenger stations was greater. The same style of railing exists, with what appears to be predominantly open posts nearest the camera. I guess at the end of the day, the company originally went for the cheapest manufacturing option
Dave F.
Western Thunderer
Hi Ian, to me as an engineer the fence posts could be T section iron notched out for the rail then bent back on it's self to form an I section hence the straight gap up the middle as the inner edges corroded away over the years, some more corroded than others so more or less of a gap.
Dave F.
Jim smith-wright
Western Thunderer
I’ve never really been convinced that mass produced pointwork captures the flow of the prototype very well. It’s one of the reasons I changed to EM gauge, somewhat spookily, from N gauge! Dave Frank’s pointwork on Wharfeside 4mm - Wharfeside, a lifetime's project demonstrates “the flow“ perfectly, much better than my own efforts.
Hi Ian
Totally agree and I think theres a couple of reasons. The main one being that real track is not built the same way that modellers lay track. Generally the track is routed to go to where it needs to go as smoothly as possible and the pointwork then built to fit it. What they dont do is have a bunch of standard points and work from them to route the track. Having studied the real thing a lot, pointwork with a straight road thats actually is straight (especially in station throats) is a very rare thing indeed. I think in my time ive only ever built one point that is truly straight in one direction. Everything else is always curved in some way.
The second reason is pointwork, even in tight locations is massive and mass produced stuff is quite simply miles too small. On New Street the ruling radius at the Bristol/Wolves end is 1 in 9 and that results in some quite mainline looking points but the reality is theres a 12mph restriction covering it all.
Lastly I don't think, no matter how careful you are, you can beat building the track in situe. The very process itself builds in a better flow in my opinion.
Keep up the good work
Jim
simond
Western Thunderer
I’d assumed they were cast iron. Possibly different patterns with same hole spacing, though I’d have expected them to be all the same. I doubt they’d have corroded through, the typical ones on promenades, open to winter storms & salt water etc seem to last a century or so…
Ian N
Western Thunderer
Quite a few years ago, I had a very interesting chat with a gent who used to work as part of the local S&T team at Princes St. Amongst other information gems, was the fact that he was involved in installing the banner repeater for a ground disc with sighting issues. The clearest photo I have of it is the Transport Treasury link above back in a June post. The image appears to show just one repeater, although the gent thought there were two on the bracket, one facing in each direction.
The closure of Hatton's, provided an opportunity to purchase a couple of Bachmann Banner Repeaters, seen here broken down into the component parts. The post has what looks like a 1mm steel wire for strength.
The bracket is assembled from Evergreen materials, and .45 brass rod for the handrails, placed together to check it looks right before final assembly, and cleaning up the soldering. IMG_6436.jpeg
Ian N
Western Thunderer
A quick second painting ( spilt the paint, then dropped the signal in it... after nearly finishing the original painting ) and it's ready for Model Rail Scotland. Handrail still looks rough at twice actual size, but will it be noticed when viewed from four feet away?
To me, the Bachman banner repeater appears to resemble the electrically lit versions, while the MSE/Wizard version seems to be the paraffin lamp version
Ian N
Western Thunderer
And finally the signal arrives on the layout. Plans to mount the bracket onto a fabricated post behind the wall went out the window on discovering that there was a block of wood supporting the retaining wall and the thick cardboard foundation for the paint factory where the post would have been. Plan B was a plastic peg screwed to the wood, and the signal bracket glued to that.IMG_2778.jpeg
Ian N
Western Thunderer
Well, as a break from working on the Larbert up building, the Princes St S&T hat has been dug out again after too many years hidden away. It started with the not-so-challenging stuff, an MSE etch which included various "fronts" for lineside cabinets. IMG_7369.jpegIMG_3089.jpeg
Attention then turned to something more challenging, the gantry outside the station between Morrison St & Grove St bridges. I'm using the Alan Gibson components as the basis for the signals. To me, visually, they can't be bettered. However, the component parts can be incredibly fragile, and don't suffer heavy handedness, or having 3" squares fall onto then with impunity.
The Gibson gantry needs to be shortened. Easy enough until you realise the end section has a corner strengthening, so it becomes a cut & shut operation. Still relatively easy (!) until you notice the top and bottom horizontals of the span have etched holes for the tabs on the upright, which no longer totally match after it's been cut up....... The answer is more cut&shut of the upper and lower horizontals trying to ensure all the cuts are staggered to maximise strength when soldered back together.
The original joined etches at the top, the modified, cut &shut version at the bottom.
Eventually I ended up with a basic span.
One side of the span is affixed to the retaining wall, the other is mounted on a leg. This is where things started to go wrong, but I didn't know yet......
The leg assembly was shortened from the three "panel" etch to a Two "panel". Allowing for the concrete "mounting plinth" this would ensure a minimum 16'6" clearance under the gantry smoke hoods and the running lines. On the workbench, the two parts looked like this. No sign of issues.......
The eagle eyed will have noticed in the reference photo that there is a cut out for the leg to go to running line level, just behind the lineside cabinet. I didn't!
When the two parts (leg and span) were tested on the layout.....
Sorry about the dustpan and brush....Don't know how I did't notice them when taking the photos. I blame the Christmas Mouse......
OK. The leg isn't perfectly aligned to the span, and the"plinth" can be tweaked further from the rail, but the plinth is stll overpowering and would possibly benefit from being shorter. Fortunately, there one on each of the four etches for the gantry, so I can make another two mistakes! The "plinth" will also be recessed approximately 1/8" into the foam trackbed which should also reduce the visual impact.
Finally, Princes St had at least five of these cabinets in the 50-60s. They may date from the resignalling in LMS days. They may be earlier. Jim Summers, author of the Caledonian Railway signalling book hasn't seen them before. Does anyone know what they are, or their dimensions, rather than guesstimates from the ladder rung spacing? Identified locations at Princes St are the north end of the station gantry (2x), one either end of slip for platforms 1&2, and adjacent to starters for platforms 5&6( per photo). There may be more! Thanks
Ian N
Western Thunderer
Referring to my reference material on LMS signals, suggested what appears to be a suitable solution to the issue of the plinth -
A photo of a leg partially buried in a platform ramp. Work on the span continues with the addition of the decking cross members, just over half the decking and a handrail. If using the Gibson decking, the bits of scrap etch parallel to the deck are the same with as the planks.
On the layout, a recess has been cut into the retaining wall for the span to locate into. the inside of the recess is still to be addressed.
The four dolls are almost complete, with just the lamp, lamp brackets and operating gubbins to be added before attaching to the span.IMG_3244.jpegIMG_3248.jpegIMG_3246.jpegIMG_3247.jpeg
One (ex) doll had a mishap.......my theory and practice of using a square needle file as an internal former for the doll went wrong on the last one. It was steel, it was coated, and you can't solder to it unless you're very determined. BUT, using slightly too much 145 solder and the liquid solder forms a key in the serrations of the file, locking it solid, with no indication of where the excess solder is. The heat and attempted gentle persuasion to try to rescue as much of the doll as possible resulted in this.
Top
