Observations of the Ruabon-Dolgelley route show that boundary fencing was usually post and wire as it was on most of the GWR system. Internal fencing was spear fencing and wooden fencing, the former being used to protect passengers. Therefore the path has spear fencing at its 'dangerous' side.
A trip into town located boxes of 'Extra Long Matches'. Each match provided three posts 27mm long. I started off rounding off the tops before 'soddit' kicked in and I changed to shamferring them with a sharp knife...
Peco spearhead fencing with boundary fencing behind. The matchsticks were sprayed light grey with a light overspray of stone...
I simply drew the wires on the backscene with a black biro and glued the posts with UHU. Vinyl Ready-Grass was used as a base. It will be detailed later. I am rather pleased with the way the field appears to drop away.
The bridge was suitably sooted before fixing to the baseboard...
Passengers use the gateway to gain access to the platform...
