Eastsidepilot
Western Thunderer
Super elevation, check rail and gauge widening ?
Col.
Col.
Pete,Thank you for your reply Simon.
You are right, none of our wheels have any significant coning - save only sufficient provided by the manufacturers to allow release from their moulds! All the stock, bar the locomotive have free running wheels on fixed axles - as per Horwich practice.
It is an issue with the loco - and I am still seriously considering the option of finally "biting the bullet" and fitting proper steel jobs...!! The real problem is that the plastic wheels were the only viable option at the time, even though they are completely wrong... and let's face it, utterly horrible... but up till now, they have actually worked! Too damn well as it happens, so there has not been nearly enough incentive to do anything about it?!
I suspect that the "terrible top curve" may end up being the determining factor?!
There is almost certainly a great deal of skidding going on at the rail head, although it is not readily apparent when examining the gunge and aluminium deposits on the tyres. The only rail contact on the massively over scale and steeply angled flanges is on the shallow, inner radius - as evidenced in the above photograph.
I am not so sure either that I am quite out of the woods with the rest of the rolling stock though - such as it is.
The chosen wagon and carriage wheels where something of a no-brainer - again at the time - and remain so at less than a fiver each, despite a significant rise in price!
Of course, there is always a downside to being a cheapskate! I have just taken another photo to illustrate the issue here.
These little beasties run so freely, that the slightest breeze catching the wagons, even down at ground level in the garden is enough to set them rolling - I kid you not! It has been the cause of some amusement during operating sessions!
However, while the wear pattern clearly shows similar contact with the rail in regular running - in this case the flange angle is far too shallow! The complete loss of "blacking" on the flange faces indicates significant scrubbing on the inner face of the rail head. Again, this has not seemed to be much of a problem on the gentle curvature.
All will be revealed... sooner, rather than later, I hope!
Pete.
Well. I guess you got them there on that one..Thanks Tony for that great suggestion!
I do have one slight reservation though....
(Copyright image shown for illustrative purposes only)
Pete.
I am not so concerned about wear, but more the combined effect of adhesion loss on the loco due to insufficient coning, and flange contact causing just a little too much drag on the following stock!
Tony (@Osgood), this ought to be one for you, where might this photo have been taken and "who" did the damage?
