AJC
Western Thunderer
While the Sentinel is shuffling back along the correct path, I've made a start on something new, though it is (yet another) brake van. This one is an early LMS vehicle, heavily inspired by Midland thinking and derived from a Parkside kit. This will be modelled as M802, pictured at York in 1963:
19/10/1963 - York.
As you can see, it's piped rather than vacuum-braked and unlike the 'pure' Midland vehicles built by the LMS has a ducket and ends with the sheeting on the inside of the framework, a design feature probably discontinued owing to water ingress at a guess. The Parkside kit of course is for the slightly later dia. 1657: LMS Brake Vans ZTO ZSO ZFQ RHQ RFQ | DM284824 diag 1657) but the main modification needed is in reversing the ends so I started there.
As supplied - much as I remember from when the kit was released there's an amount of flash around the apertures and noticeable wood graining which is perhaps a touch overdone.
Step 1 was to cut out the panels and, because I can and because the prototype pictures show it, I've decided to have the door open at one end (Parkside have the catch on the wrong side - real LMS vans seem always to have had left-hand hinged doors but no matter).
The new sheeting is scribed 20 thou'. For scribing I use the tip of a scalpel blade and a small engineer's square. Note that I cut the strip slightly over height and trimmed it down before fitting.
When assembled the basic carcass looks like this:
I've added a bit of 60 thou' amidships to prevent bowing and am now thinking about interior detail. What I did last time was to build that in situ which makes it a swine to paint. This time, I'm going to make and paint the bits separately and fit them afterwards; they'll be every bit as invisible as on the first van but it will all be much neater!
Adam
EDIT - Captain Cock-Up has visited for a second time this week! I hadn't noticed that the veranda screen on these earlier vans is lower in height than on the later ones. Now rectified.
19/10/1963 - York.
Adam
