Rob Pulham
Thanks Guys
That's a lovely set of castings. If only other makers used all brass instead of whitemetal.![]()
It is, but the buckeyes look a little on the slim side when compared to the JLRT ones.
I wonder which are accurate?
Heather,
I have ten of these Kemilway kits and actually it is the quality of the lost-wax that lets them down IMHO. At least in my ten kits there is much distortion to these parts & pitting of the surfaces. Although I like the Kemilway kits very much, I shall certainly be replacing those horrible vac. cylinder & dynamo castings with nicer cast metal ones.
I think that with cast metal you have to distinguish between pewter and almost pewter [a small amount of lead added to keep gates small & give a nice surface finish] as we use in out Mk.1s and the cheap high-lead 'margarine' metal some kits use [this is where white metal gets a bad name]. As a test we have tied and untied a knot in one of the high grade castings for the vac. cylinder feedpipe units in our Mk.1 kits and still it did not break!
I find working with lost wax can be pretty tedious with so much preperation and only the very best stuff from Slaters/Finney and MOK really acheives the surface finish you will see in the best castings. Take a look at the vac. cylinders & dynamo in the RMB kit you have there - these show what can be acheived in a first-generation casting from a brass master [no sub-mastering or other fancy messing about] direct to a black rubber mould - in the hands of one of the best military model casters in the UK [not me I hasten to add!!!].
DJP
Interesting.
I recognise the castings that Rob shows above and I'm 99% certain they're done by the same person/people who do the MOK castings. They should be pretty good.
Steph
The only draw back for me here Rob is that my two kits are parcels stock so no lavI'm loving this build, very neat work
I'm looking forward to the next instalment,
ATB Mick
Hi Mick, which of the parcels stock do you have? I quite fancy the Thompson matchboard and the Gresley steel panelled ones myself. I built a couple of the 4mm Thompsons, one from a Comet kit and one from an Ian Kirk - I much preferred the Comet...
Rob -
All this is not to say that the rest of the kits are not excellent in most ways as well! It is the bogies that are the real plus with these kits. Really quite something.
DJP
