As I mentioned earlier last week I printed an EM gauge B7 turnout and an 00 gauge V5 with a 9' switch. Given I have a slightly older machine (Neptune 4) with a 0.4mm nozzle, the results are reasonably good.
In fact it it was 2016 and not 2026 I think people would be amazed at the results. There will be some who criticize a slight dulling of detail from using the 0.4mm nozzle that could be remedied by using a 0.2mm nozzle, but at normal viewing distances could it be noticed? But what are the options available to those who criticise these prints ?
Ready To run
I have not looked close at them, but for starters the geometry is for set track and not prototypical, the broken and bent end timber etc
C&L and Exactoscale ranges
Only Exactoscale (in 4mm scale only), has a range of special chairs and for not all sizes, Exactoscale are only available through societies. But I have noticed against 3D prints the chairs seem to be overscale to my eye, those who only use C&L will have a limited type of chairs for turnouts
British Finescale
This range is to my mind the best commercially option, sadly for commercial viability it has a limited range of sizes. An easy to build kit and a cheaper option to the other commercially available options, the chairs are finely printed and a bit better than those I can print with my 0.4mm nozzle
If I were interested in 4mm scale I would either change the nozzle in the Neptune 4. Or more likely buy a Bambu A1 mini, which would give me a much more detailed print in 4mm scale. As for the range of sizes, detail and geometry, 3D printing of turnouts really come into their own, bespoke turnouts available to all
But when it comes down to costs and time saving, the reality kicks in
A V5 with a 9' switch cost 17p to print using about 1m of rail (2.15 at most) Total cost about £2.30
The EM gauge B8 would cost a little more, but not much, probably around £3 with rail.
With the CARROT format (printed wing and check rails, the build process is relatively easy and quick. similar to British Finescale kits which are even easier as Wayne preforms the rails and supplies tiebars. But then these are 3D kits
For me in 7 mm scale the Neptune 4 with a 0.4 mm nozzle is a good cost effective option, and I would add to a quality I would find impossible to match scratch building, in a verity not available commercially.
Commercial kits in 7mm scale are over £100, RTR turnouts start in the £70 + bracket
I can print a bespoke turnout for around £10 with most of the cost being for the rail
Back to a question I was asked would I buy the Bambu A2, probably if I did not have the Neptune 4 already, or needed to replace my Neptune at this point of time, but subject to asking the question to my more learned friends at Templot club probably
John
John
