7mm Pete's workbench. LNER A6. PLUS?
Not much for the week. Think I'm getting slow in my old age. But, I'm pleased with the way it's going.
Not in the kit, but, I thought I really needed to make replica balance pipes, they are rather prominent under the cab steps,
View attachment 257725View attachment 257726
Next up are the rather large tank brackets. Also the boiler top pipe and control rods.
View attachment 257727View attachment 257728View attachment 257729View attachment 257734
I even got to the stage I felt the urge to see how it looked with the chimney and dome tested in place.
I've managed one side of the cab handrails.
I do have a question, would any one know if these were left or right hand drive?
I know nothing about the class, but if that large diameter pipe running down the top of the right hand tank and going into the smokebox is the ejector exhaust or train pipe, that implies the ejector and driver's brake valve is mounted inside the cab on that side - hence RHD?
James
They were indeed RHD.
Peter Cross
Another slow week, I seem to be more tired after work.
But we have done a bit, I think we are down to major fittings now.
I've changed the tank brackets.
They look all over the place in the photo, must check them.
Did some cab details, I've gone with the lever reverser that came in the kit, but, I think being a passenger engine it may well have something else.
Theres a pipe running under footplate on the drivers side, this is now in place.
Finally I've added a couple of slotted tubes to keep the front buffers horizontal. When fitted.
Peter Cross
Now, that's the frames finished. Big clean up time and find the airbrush time.
IMG_20260227_225553096_HDR.jpgIMG_20260227_225525598_HDR.jpgIMG_20260227_225452117_HDR.jpgIMG_20260227_225513768_HDR.jpg
Right what next. I've been looking at all the part finished wagons etc that I keep buying.
A LNER k3 that's half done, that I now have more information and new parts.
Or one of two new kits, a GWR 57XX/8750, or an 6 coupled industrial loco.
AllenM
Active Member
Hello Peter
New? Gateneal with the Halesowen address must be 40 if not 50 years old.
I don't know about the Mercian but that, from the box, looks quite old/new stock
Regards
Allen
Peter Cross
Hello Peter
Regards
Allen
I thought it was a 1980's product. Hopefully the fit will not be to bad.
Peter Cross
While I'm painting the A6 I thought it was time to start another project.
It's to be the GWR 57XX. This is an old Gateneal kit. So it's quite basic. So what has been added or replaced, the safety valves and cover as the cast white metal is best kept as ballast. A set of sprung buffers. The arched brake hangers would be impossible to fit, so a set were found from the spares box. Also from there was a pair of milled coupling rods. A vast improvement over the etched brass ones in the box, but pre renamed to 8BA. I'll need to find my larger crankpins. I will specify any thing else as I use it.
First job was to open up the frame bearing holes from 1mm to fit the bushes.
Checking the footplate. A couple of splasher gaps need opening up a little. I also need to check footplate hieght. Hopefully it's low, otherwise I need to make new splasher sides.
Brakes were next. The halves were soldered together.
The holes enlarged and the outside cleaned up with a file. And checked on the hangers.
IMG_20260308_234016049_HDR.jpgIMG_20260308_233840339_BURST001.jpgIMG_20260308_233831472_HDR.jpg
I'm hoping this will not take too long to build. My main concern is to how well the tanks will fold up.
Peter Cross
Not done much this week, just cleaning up and pressing out rivets. Including ones not marked.
IMG_20260311_235928714_HDR.jpgIMG_20260310_235352755_HDR.jpgIMG_20260310_235412624_HDR.jpgIMG_20260311_233348913_HDR.jpg
Can you spot the designers deliberate mistake. The cab sides are both for the same side.
I've now cut a new one
I'm still preparing parts for assembly. Adding details that are missing from the kit. But I think will improve the model, but I'm leaving some that. I do not think will add anything as either they are not easy to see etc.
Peter Cross
Slowly getting to where it needs to be. There's a bit more work I'd like to do on the footplate. I've fitted larger splasher sides. These were taken from the drawing I have. At least now the wheels will have space to rotate. Although the insides will need cleaning out when it's remove from the wood block.
The tanks were folded up next, not quite as neat as I would have liked. I find it very hard folding half etch. So a bit of filler or solder will be used later.
I added a smoke box back and firebox front. Also needed to roll a boiler under side, measurements taken from a Scorpion kit I've just bought. I just had to shorten by a millimetre which I thout was pretty good for a fifty year old kit. But the underside of the tanks should go under further. I'm going to have to mount the boiler on something and use it to reach the tanks.
The cab front is tracked to the tanks for alignment for now will be screwed together later so hopefully the tanks will be removable. I attached one cab side for checking bunker position.
The bunker sides have been attached to the rear. With these really old kits there were no rounded corners. But there is a way around it. If you solder rod on the inside of the corner and flood it with solder the outside can be shaped.
And all the bits rested together. A few bits to adjust but I reckon the next session will see the cab and bunker assembled onto the footplate.
IMG_20260323_225347543_HDR.jpgIMG_20260323_234746458_HDR.jpgIMG_20260323_225409804_HDR.jpg
Bit more later.
Back to the Scorpio multi pannier kit I bought, well I'm going to probably build an older 655 class from it, so I can use a few of the 57XX class parts on this. Plus there are lifting hooks and others parts that are duplicated.ehich will save a little fabrication.
This will not be a state of the art 57XX. But should be a good representation.
Bigjohn
Opinions on etched kits seem to vary…….
1its an expensive way to buy metal sheet…..
2 it’s like being a mosquito in a nudist colony, not knowing where to start
3 my kit purchase . No 1 rule applies
4 put it on a shelf til later………….
But if it keeps you happy who cares
Bigj
Peter Cross
Whilst having a reset and moving stock about. I found this I suppose I ought to finish it. I now have the transfers. But I think I need to paint the roof again. I must have lacquered it with enamel. The 12 years since I painted it has not done it much good.
IMG_20260605_225013713_HDR.jpgIMG_20260605_225030864_HDR.jpgIMG_20260605_225040613_HDR.jpgIMG_20260605_225116795_HDR.jpg
I hate lining coaches but I do not think this one is too bad.
Peter Cross
I got this MR calf van back in January. I said at the time I'd already got one that I was building to sell. Well now I have this I'll keep the other one and sell this.
Now I recall saying that all it need was a roof and painting.
All good words until you start to do any work.
I've covered the louvres from the inside and added floor braces.
IMG_20260612_193531057_HDR.jpgIMG_20260612_193537841_HDR.jpgIMG_20260612_193553644_HDR.jpg
Under frame has been tidied up, W iron bases soldered in place as well as the brake bleed, and the lever ratchets. I have use plasticard as buffer ends as well as the sole bars. This gives the spring hangers something to sit on.
Whilst tidying up to make a start. Bits fell off. Buffers, brake levers and brakes. I think the door strapping was held on by the primer.
IMG_20260612_193727993_HDR.jpgIMG_20260612_193742613_HDR.jpgIMG_20260612_193727993_HDR.jpgIMG_20260612_193742613_HDR.jpg
