Tim Watson
The three Gate Stock cars are now fully illuminated, with the Tramfabriek magnetic switches working well.
A start has been made on the interiors. The 3DP seats from Graham Roberts had a good deal taken off the bottom to accommodate the false floor hiding the battery, but when painted no one will know the difference - any people in the cars will probably need below knee amputations. The other carriages will be simpler because they don’t have the live pick up bogie and so the interior flooring can be made entirely of styrene and the 3DP seats. The ‘holy’ arm rests are visible, as in the prototype:
And even on the model: thank you Graham.
The LED lights are currently illuminating in five directions: I may blank out some of the side lighting a bit, but that can wait until they get tried on the layout.
The glazing is now also fitted and the whole ensemble is beginning to look quite comfy, probably more so when it’s painted. The rear bogie needs some dummy black styrene frames, although it is virtually invisible when on the track.
Tim
Tim
