smgee
Greetings fellow Thunderers. I thought I'd start a build thread on a new Steve Beattie Class 22 kit. I'm sure I'll be calling on the WT big brain from time to time...
The kit is predominantly 3D-printed resin, with chassis components in more sturdy FDM. It wasn't hugely expensive at under £190, but not as refined as the JLTRT/MM1 offering, so I'm intrigued to see what can be made from it. This will definitely NOT be a cost-no-object build!
I decided to build a running chassis first. The frame comes in 2 sections, with some locating/reinforcing brass dowels (thick wire) at the joint faces. The faces needed a small amount of tidying, and the holes for the brass dowels needed deepening slightly. The two halves were glued together on a flat surface, up against a straight edge, using some VMS flexible black CA, which is great for seeing how much you've got on your fingers!
Next job, fit the bearings to the bogie frames. This is where I hit my first problem...
The bearings are standard 0.25" / 6.35mm OD, but the holes in the bogie frames are 7mm. I wondered about just glueing them in with the wheels fitted, sat on a flat surface, but they were all over the place and wouldn't stay put.
I found some 7mm OD plastic tube to sleeve down the bearing holes. This was glued in place, the ID opened up fractionally to fit the bearings, and the whole thing checked on a flat surface. Spot on.
The bearings were glued in and the excess tube cut away.
In case you're wondering, those slots in the cross pieces are for a Delrin chain. We'll be re-visiting those shortly!
