7mm Boris' Workbench - Jltrt Westerns (various)
Phill Dyson
Hi Phill, They'll be 1 x Ron Chaplin (D1063), 3 x ABC's (D1026, D1065, D1009) , and one (D10xx) probably Slaters (JLTRT) due to indecision:confused: with the client :headbang:. All bogies will be powered:)which means extra work:(but "Hey", I'm happy!:D
All good choices IMO:thumbs:........What's your own preference.......ABC? (BTW are you using ABC gearboxes or motor bogies?)
28ten
Guv'nor
Having used both of them the performance is good with either, it depends if you want to replace the JLTRT resin and are prepared to pay the extra. In round figures with a Maxon it comes to £220 vs £380 I have a motor bogie on the bench for one of mine and im unsure whether to get another, or flog it and get twin gearboxes..... swings roundabouts etc
Phill Dyson
Did running on one motor bogie prove unsatisfactory ?...........those Slaters/JLTRT gearboxes look OK too ;)
28ten
Guv'nor
No, they are fine up to 8 or 9 coaches which is what you would expect, but having built several Peaks, 50's and other Westerns with two it just gives a bit more leeway.
28ten
Guv'nor
Ian
I can send you a couple of test pieces for a windscreen if you like? you can see what the acrylic is like. This stuff is quite expensive but its as good as anything I have found. I have done several sets to replace the cast glazing in JLTRT mk1's and the owner was delighted :cool:
alcazar
Guest
Just seen that pic of all the control desks: It looks like an examination hall for D1xxx drivers at Swindon works.....
The empty desks are for the swotty types who finished early and have already gone, LOL.
D1054
Ian
Hi Guv, that would be great as I'm not smitten with the available alternatives I have to hand. I'll be busy with the working fans on the 52's and 26 for a while so there's no rush, Boss:thumbs:
D1054
Ha Ha! But just taken a delivery from Heroes of the Footplate today and D1xxx driving-school will be fully attended over the next few days;)
D1054
Hi Phill, Sorry for the delay in replying - been AWOL doing some real work;)
I really like the ABC gearbox sets, and will be quite happy with the "standard" + delrin which always perform well for me. The motor bogie is very nice too, but just a tad expensive when doing both bogies in a mini fleet! For D1054 (which is currently also in the Workshop for bogie replacement and new wiring, she'll be getting new motor-bogies (If she passes her "F" Exam and isn't towed out to the scrap-line!;)).
Phill Dyson
What's the problem with the current bogies on D1054?
D1054
Nothing really, just a refurb and then moving them into one of my others! Playing trains at Swindon - just like the real thing!
Actually, I'm also working on a mock engine and boiler to view through the sides, and the current internal layout isn't suitable for this on Governor, so there's a bit of redesigning going on...... (It helps to have access to D1013 and D1062 every other weekend or so:)) I'm also building a spare bogie set so that a simple drop-down and replacement is available to keep the fleet running if any were to develop a fault out at a show, etc., but it's a fair bit of extra work to "standardise" them so that the quick change can be made without effecting the DCC/all lights/fans/decoders, etc., which will now all be body mounted, and only the drive motors and wiring will be chassis mounted.
lancer1027
Hi Boris, im very interested in your plans for fitting lights/dcc/decoder etc into the body. Plus i like the idea of being able to drop down a bogie and replace:thumbs:.
I am also interested in your mock engine and boilers. Mine were ok but look forward to seeing how you get on, there bound to be better than my poor effort. Pics please;)
Rob
Dan Randall
Rob
I'd also be interested in seeing how you go about installing lighting and decoder Ian. The way I did the lighting on "Rifleman", was the first idea that came into my head, but it's always good to see alternative thinking. :)
Likewise with the suggestion of engine/boilers behind the windows, though I have to say, I still find Rob's "Engine Theatres" very convincing and have been meaning to blag his idea for some time! :thumbs:
Regards
Dan
Dan Randall
Ian - I got your latest PM regarding window etches (found them, by the way), but for some reason, the reply I sent to you over 24 hours ago, never reached you! Try your inbox again and if it's still empty, please PM me your e-mail address.
Regards
Dan
D1054
Done:):thumbs:
D1054
Hi Boris, im very interested in your plans for fitting lights/dcc/decoder etc into the body. I am also interested in your mock engine and boilers. Pics please;) Rob
Hi Rob, Sorry things are not progressing apace at the mo, but I'll certainly be posting details when I get to them! I'm working on the fans at present, and my F-in-law has dropped off his proposed solution for the H/C lights, which comprises PCB mounted flat LEDs - they're quite impressive and will certainly save space, so there's 9 more on order to go with the prototype. The mock engines and boiler will not be constructed until after I get back down to Bridgenorth at the beginning of January. Pics of progress to follow.
In the meantime, anyone know or care to guess what this is?IMG_7317.jpgIMG_7318.jpg
Christian
Active Member
Looks like some kind of rotary switch or isolation switch. I would imagine a lever would be fitted at one end.
Nice looking ornament though :)
