michael mott
Thanks for the detailed reply.
Michael
Michael
Is it too personal to ask what the wheels cost, Geoff? Mark Wood sells a single cast iron unmachined 3'1" open spoke wheel for 13.44. machining would be extra on top of that if one had to outshop them for this work.Three 3D printed London and Birmingham wagons have just arrived in the post. Printed from my CAD artwork. I used the drawings in the LNWR Soc Journal, which had been copied from Brees.
It worked out at £9.50 for a set of four wheels, from SGD3D, plus the cost of Slaters axles and brass axle bushes. The Slaters axle back-to-back is 58mm, I used 4mm brass washers to pad that out to 60mmwhat the wheels cost
What? a card loco? Without that almost throwawy line, I would have missed your thread about building a large scale loco in card. I shall pore over that thread line by line, and copy it. I have a running loco chassis which would make an ideal candidate for a body built from card.for the card loco
Michael, I've just started a conversation with you about filing curved edges on card. Meanwhile, when you say carpenters glue, is that what we in the UK know as PVA glue?Geoff some years ago I remember reading about a chap in England who build garden railway locos out of card and they were quite successful As Peter Insole stated it is such a clean "easy" material to work with, and the mistakes are not as difficult to toss because the humble material just goes straight into the recycle bin. I am finding the printable cardstock wonderful stuff to work with and three layers forms a really tough part and dilute carpenters glue applied with a 1/2 inch flat brush is a quick and easy way to laminate up curved parts.
Michael
GeoffIt worked out at £9.50 for a set of four wheels, from SGD3D, plus the cost of Slaters axles and brass axle bushes. The Slaters axle back-to-back is 58mm, I used 4mm brass washers to pad that out to 60mm
Simon,Card is an interesting option for model building, as it cuts extremely well on a laser. I had thought of doing “W” irons and other structural wagon bits (in 7mm) but being something of a butterfly, haven’t got any further than thinking…
your comment about it being “as hard as styrene” set those thoughts off again.
I think, on further reflection, fundamentally I’m a cheapskate! I’ll spend a fortune on lasers and 3D printers to save seven pence on a wagon…
(and to see “if I can”)
