Pencarrow
Morning all.
There's discussion on another thread about creation of a stand alone signalling thread. In the meantime it was suggested that signalling queries could go into the PW area.
So...
Polsarrett is my unashamedly not really prototypical foray into building a small cameo layout in 4mm. The original idea being that I could quickly complete a 5' long cameo module and then easily transport it in the back of the car. Pencarrow is my 7mm layout that is many years off completion and will need a van to shift!
I'm into the ex LSWR lines in Cornwall and Polsarrett is set in the early 1960s somewhere along the Wadebridge-Bodmin line. Essentially it's a halt, a bit like Nanstallon, on a single line branch. Like Nanstallon there's a level crossing and the box is next to that not the platform.
On it's own a single line with a halt would be a tad boring so, in true modeller fashion, I've added some sidings for a clay dries which also involved the inclusion of a run round loop. The position of the loop away from the platform face also allows for the layout to be run end to end and passenger trains run around if I only add the left hand fiddle. Ignore this latter point in considerations though.
In summary, the layout is definitely designed as a play thing rather than a slavish copy of prototype practice. I would however like the overall scene to look convincing and nothing obviously screaming WRONG to those casting an eye over the layout.
I'll add some photos of the layout in overview so you can see the track layout in a following post. My key questions though relate to:
The above are of great sentimental value as they were built for a previous layout, Treneglos, 18 years ago by a good friend who sadly passed a few years ago. Being 4mm, I have no use for them on my 7mm layout, and would dearly like to see them used on Polsarrett.
More to follow...
So...
- routing of the point rodding
- arrangement of the levers in the cabin
- location of ground signals if required
- and am I making best use of the signals pictured below?
More to follow...
