I'm not sure I should be posting this on WT. Thhis is the first bulletin in a series of periodic reports describing the adaptation of my Tonfanau Camp layout from a 1950s/60s British Railways station on the Cambrian Coast line with a private siding serving an army camp to a small wayside station in East Anglia serving an RAF airbase in the same period. I intend the the layout to be easily switchable between the two scenes. The buildings and signals will plug-in replacements and the ER station is inspired by Pulham Market on the erstwhile Waveney Valley line.
First off the workbench is this little LNER platelayer’s hut. It is built from the Roxey Mouldings resin kit, which is a robust model of just five parts. I carved away part of one of the corner posts and inserted a small length of wire to represent an exposed portion of the steel reinforcing rod.
Pre-cast concrete can be quite difficult to simulate convincingly. For this model, I used Woodland Scenics Road System Top Coat Concrete paint (ST1454). This is a thick acrylic paint that looks like newly laid concrete and can be stippled to provide a little texture if desired. The colour was too bright for my taste so I added some drops of Vajello black and dark earth to tone down the rawness. I then applied a thin black wash and finished with some matt black enamel mixed with a smidgeon dark brown brushed into the corners and then manipulated the paint with a cotton bud.
It’s probably best only to tune in occasionally as there will be long periods of radio silence between bulletins.
Chris K
