Steve Cook
Flying Squad
Thursday evening saw a piece of steel drilled and shaped to fit the chimney base and cap, I then took it round to my friend to show progress - I think I got top-trumped
As he said though, he has bought all of his stuff in though just to speed things up - it was interesting to see that his smokebox is wider and taller than mine whilst in theory both are built to the same drawings. He's done a nice job on the fake springs with them relieved on the underside to fit the Slomo unit I sold him - I'm putting in the correct 3' wheelbase on my model which means the Slomo won't fit.
I did get presented with my Christmas present though, a 60mm length of 55mm diameter steel for making my smokebox door.
Horrible stuff to machine though with hardened bits appearing at various diameters, it gave the tools a real work out. I struggled to get a good surface finish on it unless I went to a really rounded cutting tip, completely opposite to the steel used for the chimney which almost behaved like brass - I have a lot to learn about materials!
The chunk had both ends faced off, then it was mounted in the chuck and the outside diameters turned down as per the drawings.
What will be the rear of the door was then bored out to size
I had a go at parting it off, but with the tool squealing and chattering what ever I did, I gave in and used a hacksaw instead. About 20 minutes later it was mounted back in the chuck, facing the other way round and marked out for shaping, the centre boss is shown here.
The shape was generated using a rounded tool and winding the handles all at the same time to create a rough profile, this was then smoothed with a file and various grades of sand paper.
This morning saw another go at the sanding to get rid of the tool marks and the clearance hole drilled for the door handles
The excess material on the rear flange was hacksawed off and filed to give a 2mm ledge all the way round to locate inside the smokebox door opening.
The finished component placed on whats left of the steel bar.
The rest of the day has been spent making the parts for the door handles.
A little bit of silver soldering (my first) followed by a fair bit of filing
got the door handles finished which meant I could put it all together for the first time
Tomorrows job is to fabricate and hopefully mount all the brass parts to represent the door strapping and hinges.
Steve
Steve
